Old 18th Jan 2020, 6:35 am   #1
Paul Mathew
Default Interesting Loewe Opta find
This interesting "radiogram" came into my possession recently. I can't find specific info on the web for this model, but see some similar looking variations. Removing the chassis and giving it a good dusting and inspection I brought it up to voltage on a variac, and everything is working perfectly. The owner told me that it's been lying unused for some 40 years, and that his grandchildren started using the record slot as a postbox depository! The 45rpm record player is a testament to German engineering, complete with a brush on the underside of the stylus. Markings on the rear are "Voccata Box" and "Type 753W". It is an export model, as denoted by "Importe d' Allemagne", (Import from Germany). It has a selenium rectifier can, and the magic eye is somewhat dull. I will try and track down a decent replacement. I'm guessing late 50's, early 60's?
ID:	197302   Click image for larger version
ID:	197303   Click image for larger version
ID:	197304   Click image for larger version
ID:	197305   Click image for larger version
Paul Mathew is offline
Old 18th Jan 2020, 9:47 am   #2
Peter.N.
Default Re: Interesting Loewe Opta find
With a selenium rectifier probably 1950's. Never seen one of those and I was in the trade in the '50s
Peter
Peter.N. is offline
Old 18th Jan 2020, 9:51 am   #3
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Is that record deck by any chance the same one as used in the Philips 'AutoMignon' in-car record players produced between about 1957/58 and 1970? The view in photo 2 suggests that it is. These were 45rpm only players. The records used had to have the 1.5" diameter centre hole, and be 'posted' through a slot in the front. The main drawback, other than the short playing time of, at most about 7 minutes with an EP, was the tracking weight (11 grams), which, in the long term, cannot be kind to records.
'LIVEWIRE?' is offline
Old 18th Jan 2020, 10:12 am   #4
Vintage_RC
Vintage_RC's Avatar
Most unusual radiogram, looks like a quality product as you would expect from Loewe, I bet it was expensive back in the day.
Alan G6PUB, BVWS
Vintage_RC is online now
Old 18th Jan 2020, 10:17 am   #5
bluepilot
Interesting. I've seen plenty with the record player on top such as this one, but never built in with a slot on the front.
Stuart
bluepilot is offline
Old 18th Jan 2020, 2:28 pm   #6
AC/HL
AC/HL's Avatar
Originally Posted by 'LIVEWIRE?' View Post
...other than the short playing time of, at most about 7 minutes with an EP, was the tracking weight (11 grams), which, in the long term, cannot be kind to records.
On a static instrument perhaps it needn't be so high?
AC/HL is offline
Old 18th Jan 2020, 2:46 pm   #7
roffe
Being an export model with AM only narrows down the search.This Loewe Opta probably has the same(or similar) chassis.
Only difference is the cabinet and the Mignon player on the front.
This Mignon is basically the same as that used in cars,but it has different springs and motor and no heavy balancing weights.
There were surisingly many radios made with Mignon players.I have a Grundig with the slot on the side.
https://www.radiomuseum.org/r/loewe_...w3d757_w3.html
roffe is offline
Old 18th Jan 2020, 4:24 pm   #8
Tractionist
What a lovely and unusual set - the chassis looks more 'Grundig' to me! Nice find !!
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 19th Jan 2020, 9:47 pm   #9
Paul Mathew
Indeed! Apparently the fellow in the pic had one fitted in his car.
https://www.radiomuseum.org/r/philip...g2013d_75.html
My player started dragging today and sounded terrible. I removed the player and discovered the fault was a collapsed rubber bush which had caused the idler wheel to drop and not engage with the turntable correctly. After an easy fix, all is well again.
