15th Mar 2006, 9:53 pm | #1 |
Can anyone identify 89D and VCR97 CRTs?
Hi I was all having a tidy up and came across two small crt tubes one is a Cossor 4" marked 89D, and the other is a 6" marked E with a goverment arrow then VCB 97, I wondered if anyone on here knows what they are for many thanks Den
15th Mar 2006, 10:02 pm | #2 |
Re: Can anyone identify a couple of small Crts
Hi Den,
the VCR97 is an ex radar tube - green phosphor with electrostatic deflection - Most famous use was in the indicator type 62a as used with the Gee navigation system. I think the cossor tube is a 3" one? again used in military equipment.... Cheers Sean
15th Mar 2006, 10:21 pm | #3 |
the 89D is an early double beam scope tube.
Jim. |
16th Mar 2006, 8:50 pm | #4 |
Hi Den, the VCR 97 was very popular with the home built TV people of the 50's, I've still got the parts from mine. It also made a good scope, much bigger than most of the commercial ones available at the time.
The Cossor tube is a true dual beam device and I believe was fitted to the 1035 scope. Quite a long persistace if I remember with a blue trace. Ed |
16th Mar 2006, 9:27 pm | #5 |
Hi Den,
Strange, I was just doing that this evening....... Ok, 4v on the heaters (pins 3+4) 2kv ish on the first and third anode 500 ish volts on the second anode. Tie all the deflector plates to HT (for test purposes) I do have a diagram here (Cheers Danny!) that makes more sense...... Or follow this link! http://web.telia.com/~u43200663/inst/vcr97-0.htm Mains EHT hmmmm scary stuff! Cheers Sean
Engineers make things work and have spare bits when finished Last edited by Sean Williams; 16th Mar 2006 at 9:34 pm. |
17th Mar 2006, 1:35 pm | #6 |
I've just had a look at the link and one thing to watch out for is that the adjustment pots are at quite a high (-) potential and if using presets to lash it up you need to be careful when adjusting. Probably stating the obvious again but just thought I'd mention it.
Biggles. |
