4th Oct 2016, 2:24 pm | #1 |
Ferrograph Series 632 wont engage play
Hi Guys
I am just having a clear out of some vintage stuff, I have a Series 6 Ferrograph, I purchased it around 10 years ago fully serviced etc, its not been in use for at least 4 years or so when I came to fire it up two of the speed settings won't engage / lock the play fwd and rewind into position, 3.75ips works fine the other two won't make it stop on, is this a simple fix ? Thanks in advance Phil
Phil M |
4th Oct 2016, 2:26 pm | #2 |
Re: Ferrograph Series 632 wont engage play
Is the equalisation on the amp set to the correct speed?
It's interlocked as far as I remember. Martin
BVWS Member |
4th Oct 2016, 2:29 pm | #3 |
Martin
Completely forgot that if there's a mismatch in EQ it wont work, its working fine.....silly me Cheers Phil
Phil M |
4th Oct 2016, 7:13 pm | #4 |
Yes, it's caught me out from time to time!
Martin
BVWS Member |
5th Oct 2016, 9:35 am | #5 |
The hold-in ( or run solenoid) is held in by the current being drawn through the output stage ( el84) Will machine act as a straight amplifier?
