Old 13th Mar 2019, 6:33 pm   #1
Colin1949
Default Bush DAC90A query
I'm trying to identify the + terminal on the speaker, green wire or, I think the other wire is mauve colour.
Than you.
Colin1949 is offline
Old 13th Mar 2019, 7:15 pm   #2
Paul JD
Default Re: Bush DAC90A query
I can't help with the wire colours but with the speaker disconnected you can determine the phase by briefly touching a 9v battery to the speaker terminals and observing which way the cone moves. If the cone moves outwards the terminal that the battery + is touching is the + terminal.
As it is a mono radio with a single speaker it is irrelevant which way the speaker is connected though
Paul JD is offline
Old 13th Mar 2019, 8:00 pm   #3
Ian - G4JQT
Ian - G4JQT's Avatar
It doesn't matter. There is no DC going through a speaker when driven through a transformer. In fact there should never be any DC going through a loudspeaker in a conventional set up, so it never matters.
Ian
Ian - G4JQT is offline
Old 13th Mar 2019, 8:11 pm   #4
Stylo N M
looking at the DAC90A radio's i have here, the original rubber covered wire colours were green and yellow. The yellow being the positive from the output sound transformer.
As Paul JD has already exsplained, it doesn't really matter wich way round the speaker is connected, it will run quite happily eather way.
I would be a bit carefull about placing a fully charged 9 volt battery directly accross the speaker terminals, as the susspension of the voice coil, could easily be damaged, due to it's age brittleness and fragility.
Paul
Stylo N M is offline
Old 13th Mar 2019, 8:24 pm   #5
Paul JD
It matters if you have more than one speaker, either stereo or twin speaker mono. If they are out of phase you will get signal cancellation.
Good point, with an older small speaker such as this probably best to use a 1.5v battery.
Paul JD is offline
Old 13th Mar 2019, 10:28 pm   #6
Mike. Watterson
1.5V is enough for almost anything. Works even for 2000 + 2000 ohms earphones wired in series. Maybe not for Electrostatic speakers.
Mike. Watterson is offline
Old 14th Mar 2019, 1:36 am   #7
Colin1949
Thank you all for quick response. The answers. Make everything much clearer.
Old 30th Mar 2019, 12:53 pm   #8
Ian - G4JQT
Ian
Yes, quite correct - that's when it does matter. But not for mono radios with just one speaker like the DAC90A.
