24th May 2019, 11:25 pm | #1 |
Comparator circuit.
here or homebrew ?
And it's a car problem. Easy solution is to fit a piggy back unit ,where the original circuit is fused through the main unit and the secondary supply is fed via a tap, and secondary fuse, to control a relay to control the supply from the non switched ciggie lighter. So that when the ignition is off, a supply is live. But- getting a supply behind the dash means problems. My alternative idea is to use a comparator on the vehicle supply rail. When engine is running, car volts = at least 13.5. Engine off, volts = circa 12.6 . Great in theory, but can any of the wise men see any problems ? Circuit would be a clamp on the non inverting input via a Zener and a prset on th non inverting input via a pot. Theory would be for output to be high when ignition off and low when engine charging battery. Any ofthe wise men see any problems in this as it's a long time since I did any theory/practice on op amp comparators. |
24th May 2019, 11:53 pm | #2 |
Re: Comparator circuit.
I am not 100% clear from your post exactly what you are trying to do, but I can point you at at a circuit which switches a circuit on when the battery volts go below a pre-set threshold https://www.eleccircuit.com/low-volt...itor-by-lm339/ .
I've used this for an alarm, set up so that when a 12V lead acid battery has its voltage fall below about 11V, the comparator switches on the buzzer. I guess the buzzer could be replaced by a relay? B
25th May 2019, 8:14 am | #3 |
This approach is likely to give trouble due to noise and spikes present in a vehicle supply. I would also suggest it's over complex. If you examine the vehicle fuse box and fuse listing, it should be possible to find a circuit appropriately fused and live as you want it.
Look on auction sites and find a replacement fuse link with a fly lead fitted to one end. This would do your job without hacking into the vehicle wiring and is easily reversed. Leon. |
25th May 2019, 10:57 am | #4 |
Sorry, but car problems are off topic for the forums.
We do allow discussions about dwell meters etc. though,
