24th Apr 2018, 8:29 am | #1 |
Help! Sony BVM 20F1E issue.
Hello
I am hoping someone can help! I recently picked up one of these super monitors, but it seems to have an issue. When powered on (without video source) I get faint rolling diagonal interference moving down the screen (RGB). When a video source is applied, the interference freezes, leaving some very faint diagonal lines (which can only be seen when displaying a black screen). None of it can be seen during gameplay (I use it for retro gaming) and the image quality is fantastic although good black level can vary. I have tried two different SCART to BNC adaptors and unused BVC ports are plugged with 75ohm terminators on the RGB card, but not on the other card. I have heard people talking about reseating the boards or doing a factory reset? Any advice would be much appreciated! |
24th Apr 2018, 11:07 am | #2 |
Re: Help! Sony BVM 20F1E issue.
Sounds like frame flyback lines.
A photo might help. Peter |
24th Apr 2018, 11:59 am | #3 |
Thanks for the reply
Yes, I’ll Get some pics up! |
25th Apr 2018, 10:20 pm | #4 |
Do you have any additional input boards installed? If so, which ones?
29th Apr 2018, 9:33 pm | #5 | |
Guys, sorry about the late reply;
I cannot get photos to reproduce the intereference, but I have drawn a pic, see description at top of thread. I have also noticed black level is poor, Quote:
The 21D is installed I tried setting output to this RGB card, but the issue is still there Last edited by Station X; 30th Apr 2018 at 10:43 am. Reason: Link image converted to thumbnail lest it disappear rendering the thread useless. |
30th Apr 2018, 4:13 pm | #6 |
Try to remove the 21d and any other additional input cards. But you MUST remove them in the correct order as the manual says otherwise it may damage them. I had a similar issue to this and it turned out to be one of the input cards causing the issue and simply removing it fixed it.
Also, I don't have my monitor with me now to test but change the sync option from internal to external if the monitor has this option (I can't remember if it does). |
30th Apr 2018, 11:50 pm | #7 |
Do you have mean remove the 21d card completely then power on?
I reseated the two cards but no joy. Will try the deflection module tomorrow Thanks |
1st May 2018, 11:00 am | #8 |
Turn the monitor completely off, then remove all additional input cards (such as the BKM-21D). Keep the deflection module, analog (RGB), power modules in. Then try testing a few devices with the analog board.
1st May 2018, 8:53 pm | #9 |
Do the symptoms change at all when the monitor has warmed up after a few hours ?
I would suspect dried up capacitors either on the scan board or PSU. I have rarely, if ever had to re-seat boards on these monitors and have been working with them for 20 years. |
2nd May 2018, 12:50 pm | #10 |
Retrotechie is most likely correct and more experienced than me. Looking back on it, I think the reason re-seating the boards fixed it for me is because the radiation shield on one of my input cards was damaged. A recap of the deflection module and video module is probably your best bet.
2nd May 2018, 1:43 pm | #11 | |
I reseated the boards inc deflection and no change. Sounds like you could be right about the caps |
