18th Oct 2010, 4:30 pm | #21 |
Re: I bought a Linesman telephone...
Just tried out the kitchen phone, and there's not enough power to even let the phone dial, blowing into the phone results in a weak crackling in the linesman phone's handset, so, yeah, I'm at a loss.
18th Oct 2010, 4:31 pm | #22 | |
- And don't be taken in by the simplicity of your 'ornery piece of metal' dial either... This is how they are maintained (yes, I know one can tap out numbers on the cradle...)!
Regds, Russell W. B. G4YLI. |
18th Oct 2010, 5:47 pm | #23 |
I didn't measure the ringing current on the other phone (an audioline somethingorother) as the batteries have worn down below 3.5v, but all the connections I've gone over inside the linesman have been clean, almost brand new infact, the only bad bit was the battery cap which was corroded, but I've scrubbed that up to a shine, the only bit I haven't shined up is the inner ring that connects the cap to the positive wire, need to dig out the dremel-tool (well, dremel style tool) and give it a wire brushing, but as it is, it looks fine, but I don't know, it's all rather confusing.
As for the dial, yeah, that looks fun, just a good thing it's in pretty much perfect condition! I don't fancy stripping one down to clean up and fix. Last edited by Dave Moll; 18th Oct 2010 at 9:31 pm. Reason: It is unnecessary to quote the preceding post in full |
18th Oct 2010, 5:59 pm | #24 |
Dunno if it means anything, but the ringer assembly coils, which say "500Ohm" on them each measure as 272Ohms, I've completely forgotten what I learned about Ohms and resistance, so, I'm not sure what that equates to....
18th Oct 2010, 6:04 pm | #25 |
I ought to make clear I was metering the d.c. battery supply whist ringing (three hands needed! ). 2.2k is near enough the load impedance of a magneto telephone bell without the capacitor in series (sort of varies between 2.46 Z and 2.62 Z, depending on which particular bell-motor one is using). I suspect a 'Viscount' will draw less, having a lower REN, but, in any case, the ringer still draws 140mA on open-cct.
I guess if battery consumption is a problem with continued ringing and the subsequent current-drain, you could always lash up a 4.5V PSU instead.
18th Oct 2010, 6:17 pm | #26 |
I did the same with the Viscounts last night, using the multimeter in place of the battery cap, but measuring the voltage today, the batteries had been drained (and I did remember to set the phone to CB, I've read about leaving them on LB and the batteries bursting or leaking!! ), so I didn't see the point in measuring current on low batteries.
I'm considering a 4.5v PSU, just need to work out where to get one that can supply the mA's for the odd power issues. Last edited by Dave Moll; 18th Oct 2010 at 9:32 pm. Reason: It is not necessary to quote the preceding post in full |
18th Oct 2010, 7:03 pm | #27 |
Another issue, the metal strip on the battery cap is desperately thin, due to corrosion, looks like that 4.5v PSU is looking more and more likely.
Unless, I could rig up a battery pack using those 4.5V batteries with the metal strip tabs on the top, two wired in parallel strapped together, shouldn't be too difficult to achieve. |
18th Oct 2010, 10:00 pm | #28 |
Hi, the voltage on these linesmans telephones doesn't seem to be too critical, I "modified" the one that I have, which had no battery door cover, to use a 9 Volt PP3 type battery with no extra series resistance and it seems to work fine.
Andrew |
18th Oct 2010, 10:51 pm | #29 |
Were you measuring the coils in isolation, or might there have been something shunting them at the time?
19th Oct 2010, 12:14 am | #30 |
[QUOTE=twocvbloke;371551]As for the dial, yeah, that looks fun, just a good thing it's in pretty much perfect condition!!! I don't fancy stripping one down to clean up and fix.
One of my favourite parts of doing a 'phone up. If I remember correctly, one rail of a standard PC power supply provides 4.5v, not sure if that would work though. |
19th Oct 2010, 12:10 pm | #31 | |
I did manage to make the buzzer louder though, seems the locking nut on the tension spring adjuster came loose and it left it a bit limp and pretty quiet, but I've managed to adjust it so it's nice and noisy, shame there's no room for bells in there though, that'd sound nicer. I've noticed something about the voltage though, seems measuring at the line terminals yields a lower voltage than if I measure the batteries directly, while tinkering with a 20v panel meter of mine, the line voltage was about 3.5v, but the battery pack voltage (with the phone assembly removed) was correct at 4.5v, with no load of course, I'm just wondering if there's some component that's given up the ghost or something, and I'm not sure where to look. |
19th Oct 2010, 12:16 pm | #32 | |
I'll have a look into that PC power supply, got a spare 250w one somewhere that isn't any good for my main desktop PC, could be useful. |
19th Oct 2010, 12:36 pm | #33 |
No doubt you'll have studied the circuit diagram here. It will be seen that between the battery and the test-terminals are an inductor and a 27R resistor. Your battery, however, will be loaded by the mic cct (remember you're in LB mode and you need to provide speech current to your local mic), and your readings are commensurate with what I get on my instrument.
19th Oct 2010, 1:02 pm | #34 | |
Make several drawings of the circuit from the link I gave you in another post and draw out, on each drawing, in different colour pen your telephone currents for different working conditions.
19th Oct 2010, 2:24 pm | #35 |
Yep, seems I measured with the handset off-hook, on hook they each measure 510Ohms, and together they measure 1019Ohms.
As for the circuit diagram thing, erm, I'm never been one for reading them, it took me 15 minutes just to work out where the bits you were talking about were located on the map, and a little longer to find the (rather small) battery symbol. (and yes, I'm just as bad with geographical maps too!!!) |
