Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps)
Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps) You may announce components or sets for sale or offered free here. Private collectors only - no traders. You must include an exact price. No swaps.
Old 17th Apr 2017, 8:15 pm   #1
peshmann
Default Krechlok KG Golm Stereogram Cocktail cabinet WK37
Hi everyone
I have a Krechlok KG Golm Stereogram Cocktail cabinet WK37 for sale. It has a lovely little cocktail/drinks cabinet and has been looked after.
The unit partially works (ie it turns on and can hear static) but due to the tuning knob not rotating the tuning needle, it is hard to confirm. The turntable requires a new pin but otherwise works. For those with the right skills this could be an easy fix.
The unit has some minor cosmetic damage (it is over 40 years old!) - see pictures for details.
I am looking for 70 for the unit and will need to be collected from Hemel Hempstead (short distance from London) due to the size and weight.
As this is a bespoke, old and unique item, I thought I would offer it to the members of this forum.
The exact same model can be found on radio museum:
http://www.radiomuseum.org/r/krechlo...o_wk37a.html#a
Thanks!
ID:	141134   Click image for larger version
ID:	141135   Click image for larger version
ID:	141136   Click image for larger version
ID:	141137   Click image for larger version
peshmann is offline   Reply With Quote
Old 18th Apr 2017, 8:09 am   #2
Edward Huggins
Default Re: Krechlok KG Golm Stereogram Cocktail cabinet WK37
Do you mean that the BSR UA25 needs a centre stacking spindle? You say "Pin".
Edward.
Edward Huggins is offline   Reply With Quote
Old 18th Apr 2017, 7:53 pm   #3
peshmann
Hi Edward,
Apologies for not being clear.
The turntable spins which is great, however it is the turntable needle head assembly which needs to be looked at.
I have attached three pictures to help explain.
I hope it helps!
ID:	141177   Click image for larger version
ID:	141178   Click image for larger version
Old 18th Apr 2017, 9:48 pm   #4
AC/HL
AC/HL's Avatar
In picture 2, the black item is a cartridge. It looks like a magnetic one, can you provide a picture from the front to help identification. One wire appears to have broken off and will need resoldering.
The three "needles" are stylii, but they are from a BSR ceramic cartridge, not yours.
Bill, BVWS member
Old 18th Apr 2017, 10:17 pm   #5
Audio1950
I'm confused! The pictures show what appears to be a magnetic cartridge mounted on a slide-in cartridge carrier, which does not come from a BSR UA25 deck. I doubt very much that this radiogram would have been fitted with a magnetic cartridge, so where has this cartridge come from? The three styli are from a BSR cartridge which would have been fitted to the deck originally.
Audio1950 is offline   Reply With Quote
Old 19th Apr 2017, 9:01 am   #6
Edward Huggins
From the photo of the UA25 can I see the original BSR cartridge still in there, I think I can just see a screw? If so the styli are likely to be for that.
That black magentic cartridge has nothing to do with this Radiogram at all.
Edward.
Old 19th Apr 2017, 5:39 pm   #7
rockinmark
This may be a bit cheeky but if you dont need the slider/cartridge post 3 picture 2 which looks like from a garrard ap76 i am after on of this for mineso i would be interested in having it also you are not far from me so i could pop round to help you
Mark
rockinmark is offline   Reply With Quote
Old 19th Apr 2017, 8:32 pm   #8
peshmann
Hi all,
Apologies for the confusion - I am not an expert sadly
I have taken some more photos of the black cartridge which I hope will help. Having inspected further, the black cartridge doesn't seem to fit properly into the arm (looks like there is a clip) and hence might not be compatible as people suspected. I have taken a photo of the underside of the arm.
I can also confirm that the white wire on the black cartridge will need to be resoldered.
I hope this helps
ID:	141232   Click image for larger version
ID:	141233   Click image for larger version
ID:	141234   Click image for larger version
ID:	141235   Click image for larger version
Old 19th Apr 2017, 8:53 pm   #9
paulsherwin
paulsherwin's Avatar
The turnover styluses in the last picture have nothing to do with the black cartridge, which appears to be mounted on a Garrard cartridge carrier which was used in some SP25 models amongst other things.
paulsherwin is offline   Reply With Quote
Old 19th Apr 2017, 10:12 pm   #10
AC/HL
AC/HL's Avatar
Picture 2 in post 8 shows the clip for a BSR SC12M cartridge, which you can still get from Maplins I believe. They're not cheap! The wires hanging down will just plug onto the cartridge pins, but be careful, they're fragile. The cartridge will come with a stylus.
Bill, BVWS member
Old 20th Apr 2017, 8:58 am   #11
rockinmark
Yours should look like this in your arm the black slider has nothing to do with your radiogram please feel free to call me
From pm sent
Old 20th Apr 2017, 1:27 pm   #12
Edward Huggins
The latest photos show a Fidelity badged low-price magnetic cartridge. This has nothing to do wth the Golm Stereogram and the OP should not get confused by it.
Edward.
Old 20th Apr 2017, 2:10 pm   #13
Gentlemen.
The confusion over the missing pin has been cleared up.
The OP wants to sell the player. I doubt he'll be too concerned about what cartridge is fitted. Buyers can see exactly what they are and are not getting.
I don't think further discussion about cartridges is needed.
Keep the soldering iron hot.
Old 21st Apr 2017, 5:25 pm   #14
peshmann
Thanks everyone for clearing this up - I appreciate the help.
As Graham mentioned, the radiogram is still available, so if anyone is interested/knows someone who would be interested then please do get in contact.
Have a good weekend all
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
