Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Other Discussions > Member Introductions and News
Member Introductions and News A place where members can introduce themselves and post occasional news about themselves.
Old Today, 12:53 pm   #41
Default Re: From 60/40 to Radon. A Radio & TV Engineer's recollection.
Originally Posted by JulietMike View Post
Wonderful thread Lawrence, I have really enjoyed reading it and viewing Simon's excellent photographs. Thank you.
Thanks, the photo's are stunning, I tried once with my own camera when I worked down there, basically the humidity got it and in the end it all fell to bits so a bit of a failure, but I did take some photo's in one place with someone else's camera, I never asked for copies at the time and forgot all about it, then recently a photo appeared on the internet and to my surprise it was of the miner I was working with in the stope I took the photo's in! I'm 99.99% sure that I took those photos, I 100% remember him asking me to take a couple of photo's of him up in the stope.
He was from an engineering background and his stope was perfect, all the walls, back etc drilled and blasted text book style, I've enclosed the images below, Tony G on the jackleg machine, the drilling steel is a 2ft "starter" the photo's were taken after washing and barring down the loose slabs from the previous blast, the face of the bench is behind him and the machine, just below that you can see a dark shadow which is the rest of the stope back that will be blasted out during that particular lift, the photo is "posed" for obvious reasons (funk) the machine's start stop handle on the right is in the fully forward position for maximum rotational speed, the air being shut off back at the pipes in the stope's ladderway, pulling that lever back through 90 degrees shuts the rotary/percussion part of the machine off, pulling it back further introduces compressed air into the drilling steels water tube enabling the hole being drilled to be blown out (cleared)
The handle he's holding was also a rotatable control (like a motor bike's throttle grip) which controlled the compressed air into the jackleg, rotating it anti clockwise (as viewed in the photo) would introduce compressed air into the jackleg and force it's leg to extend, on the end of the handle was a small steel button, pressing that for a short period would reduce the force of the leg, pressing it continuously would retract the leg back into the jackleg tube.
ID:	186727   Click image for larger version
ms660 is online now   Reply With Quote
Old Today, 1:13 pm   #42
I don't think I will ever look at a roll of solder in quite the same way again.
Old Today, 2:35 pm   #43
I never did after that, it changed my views about lots of things.
One of the main producers of tin ore was Bolivia, the miners in those mines suffered horrendous conditions and treatment.
It was the chance of better money that attracted me to tin mining but now I often wonder if it was something subconscious from my childhood.
As a child at home up North there was a built in cupboard in a spare room, I remember opening it and a few old books fell out, one I picked up was called Coral Island, I was fascinated by the picture of a shark, another one I picked up was called Deep Down and was a book based around mining life in Cornwall, I used to thumb through those old books from time to time as I learned new words etc then I forgot about them.
Fate can be a strange thing maybe.....
Anyways the latest bunch of episodes of Poldark kicked off last night, corny in places but it's got all the classic ingredients to keep me watching.
Old Today, 4:16 pm   #44
JulietMike
JulietMike's Avatar
Thank you for posting the photo's that you took of Tony up in the stope and the explanation of working the jackleg drill. Fascinating recollections !
JulietMike is offline   Reply With Quote
Old Today, 5:06 pm   #45
No worries, my pleasure, for those photo's, I was describing a Holmans 303 but the machine in the photo is actually I think a Silver Three on closer inspection, same principle and a similar amount of din, another jackleg machine in use back then was the Atlas Copco Puma, a good machine but not quite the same punch as a 303.
Old Today, 5:38 pm   #46
LyntonP
LyntonP's Avatar
An excellent descriptive account of the terrible conditions endured by you and your fellow workers. How you endured all of this is beyond belief.
Previous generations of mine all worked in the mines, and a number of them had very lucky escapes when things went wrong.
I was fortunate not to follow them, but ended up in the relative peace and tranquillity of weaving sheds all over the world.
Never buy a mermaid a pair of socks!
LyntonP is online now   Reply With Quote
