Old 18th Nov 2018, 9:36 pm   #1
saddlestone-man
Default Oldest radio with push-pull output?
Hello All
I was wondering which UK manufacturer produced the first ever radio with a push-pull audio output stage. There were a few portables with QPP outputs in the mid-1930s, but were there mains radios with push-pull earlier than this?
Best rgds. Stef.
saddlestone-man is offline
Old 18th Nov 2018, 9:46 pm   #2
Nuvistor
Nuvistor's Avatar
Default Re: Oldest radio with push-pull output?
This one was 1937.
http://www.thevalvepage.com/radios/f...02AC/502AC.htm
Frank
Nuvistor is offline
Old 18th Nov 2018, 9:47 pm   #3
Paul_RK
Paul_RK's Avatar
Quite a few, I expect. The first RGD in 1929 had push-pull output:
http://www.rgd.org.uk/rgd1929_1934.htm
It wouldn't surprise me if Dynatron beat them to it.
Paul
Paul_RK is online now
Old 18th Nov 2018, 11:44 pm   #4
I suspect you could go back to the mid '20s probably in one of the more expensive American offerings. The technology using audio driver and output transformers was certainly available.
Edit:
Wikipedia mentions the 1924 RCA "Radiola 3" as perhaps the first commercial offering, though the principle was known even earlier.
Herald1360 is offline
Old 19th Nov 2018, 9:41 am   #5
ukcol
ukcol's Avatar
I can't answer your exact question but P_P was definitely around in the 20s.
My maternal great grandfather Herman Kloss was a classical pianist and professor of music. He had his own music school in London "Kloss' School of Music".
I mention him because of his other interests. I remember my mother telling me that he designed and built an automatic thermostatically operated window for his greenhouse and that he "invented" push-pull in radio in the early 1920s.. My mother had no knowledge of radio and so he must have made a push-pull system, but "invented" is of course highly unlikely.
ukcol is offline
Old 19th Nov 2018, 10:21 am   #6
Nuvistor
Nuvistor's Avatar
A bit off topic, I have a bit of a soft spot for the Ferguson 502 or 503, not sure which, it’s a long time ago. It was our home radio, in the 50’s, my dad would have got it second hand and repaired it.
In the late 50’s he removed it from its cabinet and installled in in a radiogram cabinet bought from the adverts in PW, fitted a three speed record player and we had a radio gram.
It’s called up cycling now, then it was make do and mend.
Frank
Nuvistor is offline
Old 19th Nov 2018, 10:35 am   #7
lesmw0sec
I once had a battery driven Pye set which had a push-pull o/p stage, using a double pentode in one envelope. It was referred to a 'Quiescent push-pull' from which I expect it was biased close to class B. The quality was excellent though.
lesmw0sec is online now
Old 19th Nov 2018, 12:17 pm   #8
I wonder if any of the sets sold by battery manufacturers had QPP outputs?
Old 19th Nov 2018, 1:24 pm   #9
TonyDuell
I don't know if it's QPP, but the EverReady Sky Monarch (both the AM-only and the AM/FM models) had push-pull output stages. They were battery-powered table radios (not the normal portable-style set). When I first saw the circuit of the AM version in R&TVS I joked that 'Ever Ready sold the batteries for this set, is that a coincidence'
TonyDuell is offline
Old 19th Nov 2018, 1:41 pm   #10
kalee20
And the Ever Ready Sky Emperor - also P-P output with DL96's - had a 'battery economiser' switch, which powered-down half the filament on the DL96's while at the same time increasing the back-bias resistor.
Who and when did the push-pull inventing? It's a brilliantly elegant scheme!
kalee20 is offline
Old 19th Nov 2018, 2:06 pm   #11
Nuvistor
Nuvistor's Avatar
Page 629 WW 13th June 1928, the article shows a circuit and gives a patent number to a Push Pull circuit dated 1915, not named as such but from the diagram obviously is.
https://www.americanradiohistory.com...ld-1928-06.pdf
Frank
Nuvistor is offline
Old 19th Nov 2018, 2:30 pm   #12
Argus25
No Longer a Member
Often radios in the 1920's era had additional add on amplifiers. The Samson company in the mid 1920's made some very nice transformers & chokes for push pull amplifiers for radios. I made a push pull amp from some of these transformers made in 1927:
http://worldphaco.com/uploads/UX-171...amplifier..pdf
There was extensive documentation in the RCA Radiotron designers' handbook in 1932 on the operation of push pull amplifiers. So probably the early 1920's was the time it was becoming popular, especially in battery sets where the energy savings of class B and the lower weight output transformers also helped too.
Argus25 is offline
Old 19th Nov 2018, 3:14 pm   #13
ukcol
ukcol's Avatar
There were special valves developed for class B2 Push Pull like the PD220 but that wasn't on the scene until 1933.
ukcol is offline
Old 19th Nov 2018, 3:16 pm   #14
peter_scott
peter_scott's Avatar
I'm not sure of the date of this one but I would suspect perhaps 1932/33.
Valves are MM4V, 354V, 2 x PM256, DW3
According to the Valve Museum the PM256 appears in a Scott-Taggart advert in March 1927.
Peter
ID:	173073   Click image for larger version
peter_scott is offline
