20th Oct 2019, 8:06 pm | #1 |
Dansette Bermuda record players. Slow turntables.
Hi I have 2 dansette bermuda mk 1 both fitted with monach turntables they both have the same faults when switched on from cold the run extremely slow and after about 5 mins the suddenly run up to the right speed.
I have cleaned and regreased all moving parts and stripped the motors and cleaned and regreased, still no joy could anyone help both valves amplifier works well and both have new original cartridges fitted many thanks nick |
20th Oct 2019, 8:15 pm | #2 |
Re: Dansette bermuda record players
Have you checked the idler wheels, they can go hard and shiny and may need redressing.
20th Oct 2019, 9:52 pm | #3 |
Re: Dansette Bermuda record players. Slow turntables.
Have you used grease where you should have used oil?
20th Oct 2019, 10:05 pm | #4 |
I have oiled the bearings and when up to the right speed it all works perfect, is there any chance the amp could be dragging it down as it seems funny when it's cold it very slow, but after it gets to right speed will play fine all day long many thanks nick
20th Oct 2019, 10:45 pm | #5 |
AS post 2 when its been running a while it will generate heat and soften the rubber giving better drive
23rd Oct 2019, 11:39 am | #6 |
No, the amp and motor run completely separately.
