26th Jul 2019, 11:39 am | #21 |
Re: Ultra 761. Actually a T671.
Yes, green and red came in with brown for tolerance. Gold is more common but suggests old stock.
It's rare now for small resistors of metal film to be other than 1% The 1% usually have three digit bands but not always. |
27th Jul 2019, 3:58 pm | #22 |
Thanks for the advice guys.
I removed the lamp limiter and replaced the reservoir cap which was a bit suspect. I am now getting 226v at the rectifier, which seems a bit off 240v. I am getting lower readings than on the service sheet. V4 Anode 222v Screen 211v Cathode 6v V3 37v V2 214v 102v 2v V1 215 102v 2.2 The radio is silent. There is crackling on the speaker when I change bands but nothing up and down the scale. Are these lower voltages normal or should I try and improve them before looking at the sound. Any advice appreciated. Robert |
27th Jul 2019, 4:04 pm | #23 |
Replace Screen Grid decoupling caps and any other HT decoupling paper caps as that kills gain and pulls down HT.
27th Jul 2019, 6:06 pm | #24 |
I have already replaced all the paper caps and electrolytics.
I didn't think the smaller pf caps had a reputation for failing. Excuse my lack of knowledge, but are the grid decoupling capacitors the ones between the grid and the negative rail. |
27th Jul 2019, 9:09 pm | #25 |
g2, screen grids. The voltage on them sets the gain. They usually connect to 0V / negative/chassis.
Check resistor feeding triode anode of V1. It's a 6C9, or there may be an ECH41 or ECH42 there. You only list one set of Anode and Screen voltages for V1. It's a Triode Hexode. The triode is the local oscillator and the Hexode g1 is RF in. Its coil is on Anode pin 3 and feed back to triode grid pin 4, internally connected to Hexode. The resistor from the coil to HT is typically 33K, I don't know what it is on the T671. If that resistor goes high resistance the Local Oscillator won't run. Pin 5 is the Hexode screen grid, to HT via a resistor and typically a 50nF or 100nF decoupler to 0V The Mica caps are generally fine. They are rectangular and up to 2000pF It's rarer that paper caps are less than 2000pF, though 1000pF and 470pF are sometimes used. |
27th Jul 2019, 9:25 pm | #26 |
Hi Robert, compared to the quoted voltages on Trader #1017 the voltages are reasonable, a bit down but not sufficient to prevent the set from working satisfactorily and so something else is wrong. The voltage measurements show that the valves appear to be drawing some current which is a good thing but doesn't prove they are working properly in every respect. To answer your question on the decoupling capacitors, yes that's correct. The capacitors between grid 2 and chassis carry a high voltage and will pull down the HT if leaky as Mike says. Also, decoupling capacitors appear between grid 1 and chassis (sometimes not completely obvious as they are often connected to grid 1 via an IF transformer coil or resistor); only appears to be one such on this radio and it's C6. If this is leaky then the radio may distort on strong signals as it preserves the negative grid bias on grid 1 under automatic gain control. Clearly not a problem on this radio at present! Crackling on rotating the wavechange switch is a good sign. So what to try next? Assuming you don't have a signal generator here are a couple of useful tips. It sounds like the audio amplifier is working but to be sure switch to gram and touch the upper gram socket with your finger. As you increase the volume you should hear a loud buzz from the speaker. Then if you have a portable transistor radio that receives AM tune the 2 radios close to the same wavelength and spin the tuning knob of the Ultra backwards and forwards across the dial. If at certain points you hear a whistle on the transistor radio then it indicates the Ultra oscillator is working. If not then a rethink will be needed. Just occasionally dirty valve pins or loose sockets can be an issue so give the valves a waggle while the set is on and see if you get a signal. Don't do this with the rectifier V5 or V4 as they get very hot. Oh one other tip: these type of valves have a locating pip on the base. If this is part of a metal shroud then no probs but if it is a moulded glass pip be careful pulling the valves out as there is a wire spring at the base that can all too easily shear off the glass pip, loses vacuum and the valve is then useless. if you can carefully release the spring before pulling the valve out. Cheers, Jerry
27th Jul 2019, 9:43 pm | #27 |
Assume you have an aerial wire plugged in?
28th Jul 2019, 3:49 pm | #28 |
Hi guys,
Thanks for all the advise.. I was going through all your suggestions one by one until I got to the resistor feeding the anode of V1.. This resistor I had already replaced as it was very high. I then noticed my schoolboy error. It is a 68k resistor and I had replaced it with a 680k. Red and orange look very similar when you get to a certain age. I think I will measure them in future. The set is now playing very nicely.. I have learned a lot working on this set. Thank you again. Robert |
28th Jul 2019, 4:22 pm | #29 |
Worth doing even if the colours are easy to see, not be the first time the odd wrong one as been mixed with correct ones in the packaging.
Frank |
28th Jul 2019, 7:12 pm | #30 |
Nice work. Well done. Cheers, Jerry
