Old 7th Apr 2019, 8:12 pm   #1
Gavinhayward
Default Grundig Satellit 1400 SL not working
Hello all
I have a Grundig 1400 SL that was owned by my grandad some years ago. I always remember it working, but the family member that had it before me has tried to use the radio on a brushless generator (not a clean sine wave) now the radio fails to work.
I have around 44 volts between the fuse and power adapter switch.
I have a multi meter and an understanding of electrics, but mainly auto based. Any help in the right direction would be massively appreciated
Many thanks
Gavinhayward is offline
Old 7th Apr 2019, 8:58 pm   #2
Boater Sam
Default Re: Grundig Satellit 1400 SL not working
Please explain which fuse, there are 3, and are we plugged in to 240v AC mains?
I have the circuit diagram and can see no obvious reason why you could have a voltage between any of the fuses and the mains input.
Have you checked all the fuses for continuity?
Boater Sam is offline
Old 8th Apr 2019, 11:53 am   #3
Boater Sam
The power adaptor switch seems to disconnect the internal 9v battery if either a figure 8 mains cable or a 10v to 16v DC supply lead is connected. Are you using the correct lead to operate the switch?
Using a poor sine wave mains source should only affect the mains transformer I would have thought, does it check out?
You need to understand which fuse is for what, do you have the circuit diagram?
Old 8th Apr 2019, 4:19 pm   #4
Gavinhayward
I checked the upper fuses for continuity I will check the lower one
I had no voltage between the fuse that is inside the voltage change over switch.
What sort of voltage should I be expecting at these and power supply.
I don't have a circuit diagram I will search and obtain one.
I've have the power adaptor that came with radio and it seems to operate switch
Many thanks Gav
