Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay). |
4th May 2013, 8:38 pm | #1 |
Replacement Drive Cord Pulley Wheels
does anyone know where to obtain substitute replacement drive cord pulley wheels. Unfortunately this afternoon, whilst tuning my Pye P75, the dial drive kept slipping. Upon closer inspection, it turned out to be one of the dial cord pulley wheels, which had literally begun to disintegrate. I suspect this is in large part due to it being situated right next to one of the dial bulbs. The plastic that it was made from had gone extemely brittle and 'crumbly', I suspect from a combination of age and heat. Ian. |
4th May 2013, 8:54 pm | #2 |
Re: Replacement Drive Cord Pulley Wheels
Hi Ian, if you have access to a lathe they can be easily turned up.
Failing that an ad in the wanted section (with a pic) should enable one to be found in the collective spares boxes. Ed |
6th May 2013, 6:43 pm | #3 |
Maybe a short tube or a few small washers with larger diameter washers either side all soldered together?
Perhaps a dead cassette deck (audio or video) might yield some likely pulleys? And maybe........ http://www.youtube.com/watch?v=e5DUvlhhjEI
....__________ ....|____||__|__\_____ .=.| _---\__|__|_---_|. .........O..Chris....O Last edited by Herald1360; 6th May 2013 at 6:53 pm. |
6th May 2013, 7:05 pm | #4 |
Hi Ian
What diameter are these? I have some small brass pulleys from a scrap Cossor 522 Any good? Cheers Mike T
7th May 2013, 5:35 pm | #5 |
Hi Mike,
it's just over 11mm in diameter. Brass would be good, as it would not age in the same way as plastic does - from the heat off the dial bulb. regards Ian. |
7th May 2013, 8:04 pm | #6 |
Hi Ian
PM me with you contact details and I will pop them in the post to you. Cheers Mike T
7th May 2013, 9:10 pm | #7 |
-Thanks Mike, PM on it's way to you.
Ian |
10th May 2013, 1:26 pm | #8 |
I have a scrap DAC90/A or two around here if the pulleys are likely to be similar you'd be welcome to them.
11th May 2013, 9:45 pm | #9 |
-Got the pulley wheels from Mike this morning, but thanks Ed for the offer.
Thanks Mike - the pulley wheel just needed enlarging of the central bore, so it would fit on the pulley wheel shaft, which is 2BA in size. The radio tuning mechanism now works perfectly, if anything even smoother. And of course being of brass they should last for many years to come. Ian. |
11th May 2013, 9:55 pm | #10 |
Hi Ian that's good news.
Glad to hear they arrived safely. Cheers Mike T
