Old 18th Jun 2022, 6:22 pm   #1
Pete_kaye
Pete_kaye's Avatar
Default Headphones mystery
I was given these today and measured 19k total with one side 2 and the other 17k, total 19k. How could thus be? The leads gave 1 ohm each. They look identical inside . Later I will test in a crystal set.
Pete_kaye is online now
Old 18th Jun 2022, 7:55 pm   #2
peter_sol
Default Re: Headphones mystery
The side you show says 2000ohms. What does the other side say? I assume you mean the resistance measured.
peter_sol is offline
Old 19th Jun 2022, 8:17 am   #3
Pete_kaye
Pete_kaye's Avatar
They are a matched pair in a headband. There was also a single Brandes headphone at 1000 ohms. A pity the other one is missing.
Old 19th Jun 2022, 9:27 am   #4
lesmw0sec
It would appear that if they are an identical pair, there is a problem with the HR one. Have a look to see if there is any green corrosion where the coils terminate inside.
lesmw0sec is offline
Old 19th Jun 2022, 10:50 am   #5
David Simpson
Should be 2K ohm, not 20ish. The leads look a bit tatty. If they are re-usable, the contact ends would need re-whipping & tinning. As the conductors are a mixture of fine copper & very fine thread - to give them flexibility.
Regards, David
David Simpson is offline
Old 20th Jun 2022, 6:06 pm   #6
Pete_kaye
Pete_kaye's Avatar
As expected , the volume in the one is good but the other quiet. I am leaving them in the sun with the diaphragms off until I delve deeper. Perhaps the bad contact is inside the coil?☹️
The diaphragms slide off easily and I remember re-magnetising inside once . Is there a link somewhere on this?
Old 21st Jun 2022, 9:19 am   #7
Pete_kaye
Pete_kaye's Avatar
Overnight, the resistance in the left hand coil has dropped to 9k, as seen in my photo. Would putting higher voltage through it do any good / harm? What is a safe voltage to use, in general?
Old 21st Jun 2022, 3:14 pm   #8
PJL
These are often faulty and it will need a rewind. Pretty easy to do but requires very thin gauge wire, a jig, and lots of care and patience. I have done quite a few...
PJL is offline
Old 21st Jun 2022, 6:10 pm   #9
PJL
FMC will be Fellows Magneto Company and I see they are using the 'Type Approved...' BBC stamp.
PJL is offline
Old 21st Jun 2022, 9:00 pm   #10
Silicon
If there is any dampness or corrosion between the metal components (i.e. bolts washers, etc)
you could get additional resistances or small voltages which would affect the test meter.
Silicon is offline
