21st May 2022, 7:22 pm | #1 |
New Member
Bell and Howell Filmosound 592 valve amp help.
Hello, I subscribed to ask if by any chance someone here would have the service manual of the Bell and Howell 642 16mm Projector.
https://ian-partridge.com/bh_642.html This has a tube amp has two row of tubes : upper row = EF86 - EF86 - EF86 lower row = EL84(6BQ5) - EZ81 - EL84 - EL84 - ECC83(12AX7) the downer row is the EF86 used probably as preamp for the mic input and/or the light cell (for optical sound) and the upper is the rest of it. Does someone have a schematic of this machine? I don't know if it works I don't want to fry anything if someone one day put the tubes back in the amp without watching where is what. It seems strange to see 3 EL84... |
21st May 2022, 9:39 pm | #2 |
Re: Bell and Howell Filmosound 592 valve amp help.
It's possible that one of the EL84's is used as a high frequency oscillator, to drive the sound exciter lamp. 50Hz is no good because the light will vary at 100Hz rate - it needs to be either DC or high frequency. And HF was often easier than having metal rectifiers and smoothing.
22nd May 2022, 12:13 pm | #3 |
Have you contacted Van-Eck video services? They may have what you are looking for and will provide a PDF for a small charge... (Search Van-eck.net).
22nd May 2022, 4:50 pm | #4 |
