15th Apr 2022, 5:22 pm | #1 |
Location: Burntwood, Staffordshire, UK or Kabaty in Warsaw Poland.
Grundig 2068 Output Transformer Fault.
A Grundig 2068 I am working on had a random crackle which I managed trace to the output stage before a loud crack, bang and buzz occurred from the speaker followed by the blowing of the mains input fuse.
Probing around the output transformer, I am measuring 22 ohms to ground from the primary centre tap, 37 ohms to ground at the HT end and 800 ohms to ground at the valve end. This is with the centre tap and valve connections isolated. From this I deduce that the transformer probably has an internal short to ground somewhere down from the centre tap. Any suggestions on how to proceed, maybe isolate the transformer from chassis? Cheers Mark |
15th Apr 2022, 5:32 pm | #2 |
Re: Grundig 2068 Output Transformer Fault.
I think the OP has done that.
15th Apr 2022, 5:32 pm | #3 |
At the moment I only have the 1.3K connection, but I could disconnect it to be sure.
15th Apr 2022, 5:33 pm | #4 |
Yes. I realised my mistake and deleted my post, but obviously not before you saw it.
15th Apr 2022, 5:42 pm | #5 |
Ah - a couple of posts have gone?
15th Apr 2022, 9:54 pm | #6 |
Just an update for anyone who's with me on this post.
I lifted the transformer clear of the chassis, but still had the low impedance to ground. When disconnecting the secondary to ground wire the low impedance went away, so now it looks as though it is a primary to secondary short instead of to ground. I'm not sure how to get over this problem now, looks like I need another transformer, but they could be as rare as hens teeth. |
15th Apr 2022, 10:14 pm | #7 |
If the secondary is on the outside of the bobbin, rewind it after replacing the insulation beneath. A loudspeaker secondary is easily wound by hand as there will be of the order of 60 turns of thickish, easily worked wire. It's likely that the existing wire can be re-used if you're careful.
Leon. |
15th Apr 2022, 10:30 pm | #8 |
Thanks Leon for that suggestion, I've never rewound a transformer before so there's always a first time though.
I was wondering if I could blast it away with some current across the Pri - Sec without damaging the primary wire, but then again the S/C must be fairly stubborn to blow the mains input fuse. |
15th Apr 2022, 11:38 pm | #9 |
NO !!! You cant blast it away. You will blast the transformer into oblivion.
If the transformer has flashed over ( which it sounds like to me ) it will need rewinding. As Leon has said, the secondary is easy. A little transformer like that ( Especially Grundig ) will be a major PITA !!, for the primary. Trust me I have wound a few. They tended to make very special layering, even for a simple class A single ended output transformer. Yours also has a choke winding to supply the rest of the set before the output stage. Maybe talk to Ed Dinning. Joe Last edited by joebog1; 15th Apr 2022 at 11:39 pm. Reason: Punctuation |
16th Apr 2022, 8:57 am | #10 |
I'm in Joe's camp. Personally speaking, I would be reluctant to attempt a rewind myself. There are many turns of very fine wire in the primary and if you have never done it before it is likely to be a non-trivial task. There are some pitfalls such as sometimes there is a gap or insulation between the laminations that alters the inductance. If it were me I would ask member Ed Dinning if he would rewind it for you. Cheers, Jerry
16th Apr 2022, 11:09 am | #11 |
The 37 Ohm winding and R39 form part of a hum reduction circuit.
Obtaining an exact equivalent transformer or getting the faulty one rewound are the least complicated options. It should be possible to use a standard EL84 compatible output transformer if your speaker impedance is one of the typical values, 3 or 8 Ohms. You may need to add an extra stage of HT smoothing to reduce the hum to its previous level. |
16th Apr 2022, 11:48 am | #12 |
There is a number on that transformer, can you post it, please? I might have one somewhere, I think so, I’ll go on the tranny hunt tomorrow morning.
Failing to prepare is preparing to fail ... |
16th Apr 2022, 12:03 pm | #13 |
Reasonable reproduction can be had from a standard single ended tranformer but fingers crossed for a donor transformer for you.
Valve equipment repairs since 1968 https://jonsnell.co.uk |
16th Apr 2022, 12:25 pm | #14 |
Thanks everyone for your expert suggestions which I will ponder over.
The sets probably not valuable enough for the cost of a transformer rewind, the cabinet was a bit battered but the chassis looks as though it's just come off the production line, after a clean up. Valvostef the writing on the transformer is:- GRUNDIG Ubertrager 9054-007 Cheers Mark |
16th Apr 2022, 2:01 pm | #15 |
OK I’ll have a look tomorrow morning.
17th Apr 2022, 8:48 am | #16 |
Sorry, couldn’t find it, I suppose I gave it away sometime.
17th Apr 2022, 8:54 am | #17 |
OK thank you very much for looking.
Mark |
17th Apr 2022, 11:45 am | #18 |
I have a random 35:1 output transformer with a hum tapped primary, fixing centres 63mm. Interestingly it's part of a stash I bought from ValvoStef a couple of years ago .
If it's of any interest you can have it for the cost of postage. HTH
17th Apr 2022, 12:57 pm | #19 |
Thanks very much for that kind offer Herald1360, I will let you know later maybe tomorrow. Sadly easter family things are getting in the way today.
A survey of old sets in the garage early this morning has unveiled a rather tatty Grundig 3365. Maybe the TFR from that would be suitable, but I have not decided if it's one to restore in the future yet. The other complication is that on the 2068 the secondary connections to ground and the tone circuitry are made via inner taps off the secondary not as shown on the circuit. Mark |
17th Apr 2022, 1:05 pm | #20 |
Hello,
I have an output transformer salvaged form Grundig 2043 or 2035 or similar. It may boast a few extra windings, however, I feel it’ll do the job in an EL84 based Grundig radio with a ‘choke’ tap in the primary. As far as I can remember it’s OK, but when I’m in the workshop later I can get the meter on it to find out. Your more than welcome to it, if it’s of use that’s of course if it measures OK! Pictures attached. Regards Terry |
