21st Oct 2005, 6:01 pm | #1 |
Restored Hacker herald VHF
Hello All This poor radio came from a friend and has been sat in the corner for months last night I decided to have a go at restoring it. Well the the chassis was ok just needed an aerial and a good clean the case on the other hand was very dirty and the rexine had a rip in the front so gave me a chance to try recovering it and it is harder then it looks anyway I got there in the end it isn't perfect I know but looks better then before I started the scale is a bit naff so if anyone has a spare please PM me thanks
21st Oct 2005, 6:05 pm | #2 |
Re: Restored Hacker herald VHF
Looks good.
The scale isn't too bad, is it? There's often damage to the periphery of these, due to the self-adhesive foam that was stuck onto them to prevent rattles. Don't switch the gas on Nick. |
21st Oct 2005, 9:08 pm | #3 |
thanks Nick I did remember to turn the gas off
Andy |
21st Oct 2005, 9:15 pm | #4 |
BTW, you can smarten up the volume knob by re-doing the white line:
Use a toothbrush and foam cleaner to get it really clean. Don't worry if the old white paint is lost. Mask either side of (and above/below) the groove with Sellotape. Press it well down. Then run a bit of Tippex (or white paint) into the line, using a tiny artists' brush. Let it dry. Finally, remove the tape, and scrape off any slight excess with a fingernail etc. Polish the knob with a bit of Pledge/Mr Sheen etc. This can make real difference to the set's appearance Nick. |
26th Oct 2005, 9:57 pm | #5 |
Andrew,
When you replaced the Rexine, did you also renew the foam padding which lives underneath (which was probably nothing but orange powder after 35 years or so)? Nick. |
26th Oct 2005, 11:09 pm | #6 |
Hello Nick yes the foam padding was replaced the problem I had was with the corners as you can see I think the origonal was steam pressed allso repainted the line on the on/off volume control
Andy Last edited by Andrew c; 26th Oct 2005 at 11:14 pm. |
27th Oct 2005, 1:49 pm | #7 |
wow!! all these Hackers undergoing restoration--I must say that I think the Herald range is the absolute King when it comes to portable AM and FM listening............................I own one of each, and its a great pity that they didnt go up to 108mhz--several valve table sets did by the late 60s............................................ian j
27th Oct 2005, 10:20 pm | #8 |
Hello Andy,
Gosh youre brave recovering a radio case with rexine !!! Not easy ..... I havent got a Herald yet but I know where there is a VHF one going, the rexine on that one has gone all flabby so if I acquire it Im going to try and tighten it up .... Regards.....Howard |
