Old 3rd Jun 2016, 4:15 pm   #1
60 oldjohn
Default ID PCB & Circuit ?
Anyone know what this board is from? Also was the PCB made like this to deter copying ? Anyone know how it was made?
John.
ID:	125447   Click image for larger version
60 oldjohn is offline
Old 3rd Jun 2016, 5:17 pm   #2
Jon_G4MDC
Jon_G4MDC's Avatar
Default Re: ID PCB & Circuit ?
Looks to me like a prototype board that they never finished wiring up?
Unless there are connections on a buried layer I reckon it's waiting for some point to point wiring.
I could be wrong though!
Jon_G4MDC is offline
Old 3rd Jun 2016, 5:22 pm   #3
TonyDuell
I think there are buried layers.
It looks somewhat IBM-ish to me, but I can't think what it came out of.
TonyDuell is offline
Old 3rd Jun 2016, 5:31 pm   #4
G6Tanuki
G6Tanuki's Avatar
Yes it does look to be IBM-style. Could be from almost anything: a terminal, a cluster-controller, a tape-drive, a DASD-controller, a minicomputer. The same style was used on all of them (up to and including the 30XX mainframes).
There are buried layers, yes: I recall seeing the early CAD shortest-path-routing-system used to design them when I visited IBM Hursley in the late-1970s. It could even do things like sometimes putting little zigzags as 'delay lines' in short routes so the clock-signals arrived at all the desired places precisely in-phase with the signals that had (of necessity) traversed longer paths.
G6Tanuki is offline
Old 4th Jun 2016, 10:16 am   #5
60 oldjohn
What is not clear on the picture there is a 24pin end entry socket mounted across the end of board, could be mistaken for another chip. The big chip is Intel 77. So late 70s IBM would seem right,
John.
Old 4th Jun 2016, 11:45 pm   #6
Dual Standard
Without doubt it is IBM but not one I ever remember seeing, the additional connector pins on the top edge are very unusual. The white plastic section on the reverse side of the card has slots that mated with locating lugs on the board that the card plugged into. This style of logic was referred to as MST.
The 1470828 is a part number but it may not be for the populated board, 53G probably relates to a manufacturing plant, 55 was Greenock, 57 Havant and I think 53 was Vimercate so it maybe from an early EPOS system.
Mike
Dual Standard is offline
Old 5th Jun 2016, 6:41 am   #7
60 oldjohn
Thank You Mike, I think some one will come up with its use eventually. Every bit of information is one step closer.
John.
