31st May 2016, 9:31 am | #1 |
Capacitor polarity ID.
Which is the pos the thin one or the thick one?
Cheers, Mick. |
31st May 2016, 10:43 am | #2 |
Re: Capacitor polarity ID.
Without more info I would go for the thin one being positive.
Hopefully there are some markings on the body or the pins. Frank |
31st May 2016, 10:54 am | #3 |
I have a lot of these green capacitors and hadn't realised that they had no polarity markings.
Give me a couple of hours and I'll test one (hopefully not to destruction!) and let you know the result.
31st May 2016, 11:04 am | #4 |
Is that a commercially-applied re-forming date label? What does it say and how does it compare to the manufacture date?
Perhaps there's continuity from neg tag to case? |
31st May 2016, 11:22 am | #5 |
I have several of the caps which are made by Plessey. There are no polarity markings at all. The can isn't accessible for continuity testing as it's entirely covered in plastic.
31st May 2016, 11:28 am | #6 |
It has all the air of a military label, from the era of large, regular intake- possibly even National Service- and the need to occupy idle hands, the "whitewashing coal" syndrome! Would a commercial organisation really bother with re-forming, or would they just sling them out and buy new?
31st May 2016, 11:52 am | #7 |
Wide tag negative.
Narrow tag positive. Final answer.
2nd Jun 2016, 11:11 am | #8 |
Thank's for the info Graham, the reform date is June 1972. Mick.
2nd Jun 2016, 12:07 pm | #9 |
It's a diversion from OP, but I'm still intrigued that it has undergone formal reformation as late as 1972 when electrolytics were no longer remotely exotic/expensive components. It seems difficult to believe that a commercial organisation would be able to justify any cost/benefit over discarding/replacement and it also seems difficult to believe that the military would countenance putting superannuated stock of such a relatively trivially priced component into, well, just about anything.
Reforming electrolytics is something I occasionally do when working on old stuff, but I'd classify it as recreational/curiosity more than anything else and only if it is a fairly key mechanical/appearance/presentation sort of thing. I'm not a profligate sort of person but if there's the slightest doubt about a capacitor or the chance of it ruining an expensive rectifier/transformer/whatever, it'll be swapped for a good quality modern component. Just a tad intrigued! |
2nd Jun 2016, 4:40 pm | #10 |
Perhaps reforming avoided the paperwork required for replacing an old component with a slightly different modern component?
