Old 8th Sep 2019, 6:50 pm   #1
Snarf81
Snarf81's Avatar
Default Samsung WS-32Z419D CRT tv not turning on.
Hi all.
My Samsung WS-32Z419D crt tv has decided to show an orange light in the stand-by display and it's not turning on.
It was working fine this morning before I unplugged it to do some decorating.
Connecting it back up and an orange light now appears where it's usually red.
Does anyone have any suggestions to what it could be please?
Many thanks
Richard.
ID:	189720   Click image for larger version
ID:	189721   Click image for larger version
Snarf81 is offline
Old 8th Sep 2019, 7:33 pm   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: Samsung WS-32Z419D CRT tv not turning on.
You are certainly in stand by,I wonder one are the batteries ok in the remote?And two having unplugged it,then it may be showing up some duff caps in the secondary of the power supply.
HamishBoxer is offline
Old 8th Sep 2019, 7:43 pm   #3
Heatercathodeshort
Heatercathodeshort's Avatar
As HB has mentioned, electrolytic capacitors in power supply have probably dried out and gone O/C. The warmth with the receiver in stand have kept them hanging on but a total switch off finished them off. Change them all.
The most common fault with flat screen models. John.
Heatercathodeshort is offline
Old 8th Sep 2019, 8:34 pm   #4
HamishBoxer
Thanks John,and back in the day of a certain SkyBox sat receiver,when the mains went off in re applying it was good bye to all the silicon in the power supply!
Old 8th Sep 2019, 8:35 pm   #5
Snarf81
Snarf81's Avatar
Ahh, thank you for the replies!
I know the batteries in the remote are fine, but I'd never seen an orange light before.
I've never had the back off it before, so I'll have to have a rummage to check out the power supply. Would the duff capacitors be bulged or visibly defective?
Many thanks again
Richard.
Snarf81 is offline
Old 8th Sep 2019, 10:36 pm   #6
jayceebee
jayceebee's Avatar
Faulty capacitors can sometimes be spotted with the just the naked eye. See here https://www.robotroom.com/Faulty-Capacitors-1.html
John.
jayceebee is offline
Old 8th Sep 2019, 11:29 pm   #7
Snarf81
Snarf81's Avatar
Lovely, thanks, John!
I'll get the back off the set tomorrow and see what's lurking on the power supply board and post a few pictures.
Richard.
Snarf81 is offline
Old 8th Sep 2019, 11:30 pm   #8
toshiba tony
toshiba tony's Avatar
I seem to remember this one. Amazed no one else has. An orange standby light!!! Red and green give an orangey glow. Can't remember the cause but we used to buy an artic a week of Samsung returns a week and this symptom was common. Both sections of the standby led is lit.
toshiba tony is offline
Old 8th Sep 2019, 11:42 pm   #9
ben
ben's Avatar
Don't know if it was just me, but I never had much luck with later period CRT Samsungs. One 28" s53A chassis that came my way had this symptom. Line transformer duff. A replacement from HR, which I had to fit as the original was NLA, lasted about nine months.
The heat sinks were truly pathetic for both the SMPS and the LOP stage, they always seemed to run hot as a result.
Another one had a tube go weak after only 3 years or so. ISTR reducing the value of one resistor on the CRT PCB gave it a bit more life.
Another of similar vintage had a PSU which seemed to consist of little more than a dozen tiny zener diodes! Fiddly work... At least that worked after a rebuild that took far longer than it should have done.
Sorry for the rant, and hope you get yours going!
Ben.
ben is offline
Old 9th Sep 2019, 1:59 am   #10
toshiba tony
Yes, the Plano range was bad. We scrapped lots of the 28\32 FST sets due to purity errors. We had dealerships for Samsung and Sharp. Even the Sharp GS was better than the Samsungs. Sharp's were full of class d and ran cooler. The audio outputs didn't have a sink on it. The 32 Plano weighed a ton. I could just about manage one on my own, changed a tube on one. Took it out, discharged it first, was walking across the w\s and got a kick off it across my chest. I hung on to it though, 30 years on I still shudder thinking about it.
Old 9th Sep 2019, 11:51 am   #11
Snarf81
Snarf81's Avatar
I've got the back off the set and I can't see any visibly duff capacitors, a lot of dust though. Haha.
I'll now check the regulators(?) for crack solder joints.
Pics attached.
Richard.
ID:	189750   Click image for larger version
ID:	189751   Click image for larger version
ID:	189752   Click image for larger version
ID:	189753   Click image for larger version
Snarf81 is offline
Old 9th Sep 2019, 2:23 pm   #12
Snarf81
Snarf81's Avatar
Success!
The caps all looked fine. I did resolder some dodgy looking joints on the regulators/heatsink, it still didn't turn on.
Then I noticed that a connector on one of the boards had a loose/broken solder joint. I resoldered it and the darn thing came back to life!
I've attached a picture on the board and a close up of the dodgy connector.
Many thanks for the replies and advice, it's much appreciated.
Richard.
ID:	189779   Click image for larger version
ID:	189780   Click image for larger version
ID:	189781   Click image for larger version
Snarf81 is offline
Old 9th Sep 2019, 8:32 pm   #13
ben
ben's Avatar
Was it the one marked AKB by any chance? That sounds like the tube blanking circuit which measured cathode emissions
Ben.
ben is offline
Old 9th Sep 2019, 9:58 pm   #14
Snarf81
Snarf81's Avatar
It was CN05, NC top pin that had a totally cracked and loose solder connection. Moving the set about must've caused it to fail?
Richard.
Snarf81 is offline
Old 9th Sep 2019, 11:47 pm   #15
Lloyd 1985
Lloyd 1985's Avatar
I always thought NC meant no connection? Good that it’s working again though! I have one of these Samsung’s tucked away in storage, is yours the one with built in freeview and HDMI socket?
Lloyd
Lloyd 1985 is offline
Old 10th Sep 2019, 2:06 am   #16
Snarf81
Snarf81's Avatar
Hi Lloyd,
Yes, it's got built in freeview and hdmi socket. It works a treat with all of my old vcrs.
Richard.
Snarf81 is offline
Old 10th Sep 2019, 8:54 am   #17
HamishBoxer
Those purple or mauve one,s I have had dry up before.The duff one,s do not always look obvious.
This is where a good ESR meter comes in.
Still,you have a good result and yes NC is normally no connection.
Old 10th Sep 2019, 11:20 am   #18
Snarf81
Snarf81's Avatar
I've made a note of all the electrolytic capacitors on that main board, so when I get the chance I'll order new ones, then I'll replace the lot so I'll know it'll hopefully work for another 10 years or so. Haha.
Incidentally, that connector with the broken solder joint, the cable went to a small PCB that was mounted to the facia of the tv on the left hand side bottom (as you look at it from behind).
Thanks again for the advice on it!
Richard.
Snarf81 is offline
Old 10th Sep 2019, 2:14 pm   #19
Snarf81
Snarf81's Avatar
Can this be closed now please Mods?
Again, many thanks for the advice on it.
Kind regards
Richard.
Snarf81 is offline
