23rd Nov 2019, 6:46 pm | #41 |
Re: Dansette conquest output transformer
With the wire disconnected is there any voltage between the secondary winding and the chassis?
23rd Nov 2019, 7:06 pm | #42 |
Station X good thinking.
300VDC that's with the primary connected and the secondary wire disconnected. Looks like a short between windings yet multimeter doesn't seem to show this. |
23rd Nov 2019, 7:11 pm | #43 |
It’s useful to have a “megger” to check for insulation break down, but the test you have carried out, as suggested by station x, seems to prove the point.
Cheers John |
23rd Nov 2019, 7:13 pm | #44 |
That's because the voltage supplied by your meter isn't enough to "break down" the fault. I wouldn't give up on the transformer yet. It's insulation breakdown, not a hard short. Keep it in a warm place for a few days.
23rd Nov 2019, 7:14 pm | #45 |
suppose dunking it in water didn't help.
the guy switching it on didn't do it any favours either. suppose the 300VDC was doing what the megger would.. New O/P Transformer it is then.. its been a good way of introducing me to valve amps so thanks to eveyone.. |
23rd Nov 2019, 7:19 pm | #46 |
What resistance range did you use when you checked the windings to laminations and between the primary and secondary windings.
Mike |
23rd Nov 2019, 7:28 pm | #47 |
auto its a fluke so usually quite good.
23rd Nov 2019, 7:29 pm | #48 |
From the first photo of the transformer it looks as though its got some damage to the windings its just difficult to tell because its so old.
23rd Nov 2019, 7:49 pm | #49 |
If drying it out doesn't cure it , assuming the secondary is on the outside you could unwind it,put some insulating tape over the primary, the assumption being that the existing insulation is punctured due to physical damage, then rewind the secondary back on, it is probably only one or possibly two layers of windings. Before going to that trouble check the underside of the tagstrip on the transformer for any problem !
23rd Nov 2019, 7:56 pm | #50 |
Its had two weeks of drying out.
I will get a replacement thanks |
1st Dec 2019, 4:34 pm | #51 |
Fitted a replacement output transformer and it's back to its old self sounding good
1st Dec 2019, 4:45 pm | #52 |
That's good. Which transformer did you use as a replacement?
1st Dec 2019, 11:26 pm | #53 |
Got another old conquest swapped it out of that one
2nd Dec 2019, 9:50 am | #54 |
Was it from the same type of amplifier? The 2 versions of the Mk1 Conquest used different output valves.
Edward. |
