2nd Aug 2007, 11:09 pm | #1 |
Do you know this valve? Mullard QV05-25
Hi - I suspect this is the right forum for this post (pls correct me if wrong)
Can anyone tell me what kit used this tube? and for what function? I think this was a transmitter tube of moderate power, but keen to tap anyone's greater wisdom. Especially if it's been successfully put to other uses. Cheers, Dave |
3rd Aug 2007, 12:17 am | #2 |
Re: Do you know this valve? Mullard QV05-25
It's an 807 in disguise, look up the 807
3rd Aug 2007, 7:49 pm | #3 |
Hi!
Mullard QV05-25; do I know that valve? Bet your life I do - and so do a lot of Radio Amateurs! It's Mullard's version of the ubiquotous 807: as popularly featured in the WW2 transceiver the "19 set" - amongst others. Although it is intended primarily as a "small transmitting valve", it pops up in all sorts of places: high-power AF amps., modulators for AM transmitters, pass-valve in linear regulated power supplies, early / vintage signal generators, RF amplifiers (class - A, B and C) to 60 MHz (reduced power O/P to 120 MHz). It's a beam tetrode on a UX5 base. Va max 600-v., Ia max. 100 mA, max. plate dissipation 25-watts (hence the "25" in QV05-25), 40w max. RF output. One of the oldest "universal" power valves in the business. Been around for ages. Only possible snag is its high power gain: so you have to take the usual precautions at RF to avoid instability. Al / Skywave / 03-08-07 // |
3rd Aug 2007, 11:08 pm | #4 |
Fantastic - thanks both! I'll digest this lot and do some more thinking/searching.
Is it fairly available do you think? Dave |
5th Aug 2007, 1:08 pm | #5 |
Hi.
Is it (QV05-25) "fairly available"? Not wishing to indulge in petty pedantry, it kinda depends on your criterion of "fairly available" . . . e.g. in Amateur Radio circles (especially Old Timers), most likely . . . . from places like Maplins . . . no chance! If you are after NOS, try the usual commercial outlets - like Billington Valves, etc. A quick Browse on the 'Net should reveal sources. A general "ask" on this Forum could produce a favourable result. Al / Skywave |
5th Aug 2007, 7:32 pm | #6 |
A couple of years ago i bought a couple of new old stock 807 valves from Russia via ebay. The total cost was less than a tenner and the valves were of very good quality.
Malc Scott |
