27th Nov 2019, 3:44 am | #1 |
Rigonda Bolshoi help.
I have a Rigonda Bolshoi with a power supply fault. When the power supply is turned on the transformer starts buzzing very loud and starts getting very hot. Hot to point starts smoking. This is not a loose core problem the core is fine. Any idea what could be causing this?
27th Nov 2019, 12:05 pm | #2 |
Re: rigonda bolshoi help
It could be lots of things. What is your level of expertise? Do you have a test meter, soldering iron etc.?
28th Nov 2019, 12:19 pm | #3 |
Re: Rigonda Bolshoi help.
Unplug the multiway connector from the main chassis. Does the tx still buzz with this disconnected?
If it dosn't, then you have a short cct on the main chassis. If it does then there are two bridge rectifiers on the psu which could be faulty. I found that the rec and caps on this unit to be very reliable, but you never know. If the tx has smoked then it is likely that a winding has burnt out and may not useable. There are two primary windings for mains, and six secondaries for ht, bias, and heater supplies. Never switch on a vintage valve unit until all major components have been tested, and then run it up on a variac very slowly. John. |
