Old 18th Jan 2019, 10:37 pm   #1
matspar
matspar's Avatar
Default Mystery set to identify! pre-war?
Good evening all,
A mate and I have made an interesting discovery on the South coast where this mystery set has been unearthed. I've been through all the books but can't seem to identify it (yet!) The cabinet depth, crt, and internals are all shouting pre-war mains eht but I'm undecided. Any thoughts chaps?
ID:	176662   Click image for larger version
ID:	176663   Click image for larger version
matspar is offline
Old 18th Jan 2019, 11:12 pm   #2
Lloyd 1985
Lloyd 1985's Avatar
Default Re: Mystery set to identify! pre-war?
Interesting set, looks a bit home-made to me, but I could be wrong!
Lloyd
Lloyd 1985 is offline
Old 18th Jan 2019, 11:18 pm   #3
paulsherwin
paulsherwin's Avatar
I also thought it looked home made, or is maybe a prototype, but I don't know much about prewar tellies.
paulsherwin is offline
Old 18th Jan 2019, 11:32 pm   #4
That bulge on the front is a magnifier to make a small crt look bigger. You may find something without it is what you're looking for.
If that red cylinder is an EF50, it'll be postwar.
Found it- it's a Premier kit set.
https://www.radiomuseum.org/r/premier_televisor.html
There's a picture of an identical one in the Science Museum collection at:
http://collection.sciencemuseum.org....ision-receiver
Yours has a nicer cabinet!
Herald1360 is offline
Old 18th Jan 2019, 11:48 pm   #5
It's post war (EF50's) Premier televisor (kit):
Old 19th Jan 2019, 9:31 am   #6
Heatercathodeshort
Heatercathodeshort's Avatar
That was working a long way from AP. They worked very well if built with care.
That boil needs to lanced..
J.
Heatercathodeshort is offline
Old 19th Jan 2019, 11:17 am   #7
lesmw0sec
Nice to see the old Pye coax connectors. They were in profusion on WW2 kit and the market was full of them post war.
lesmw0sec is offline
Old 19th Jan 2019, 11:34 am   #8
matspar
matspar's Avatar
Ah a Premier kit! Brilliant! I did suspect it could be a home-brew set. Then we thought it could be pre-war but heavily modded (hence the EF50s) great to finally pin it down.
matspar is offline
Old 19th Jan 2019, 6:54 pm   #9
Yes, they persisted well into the 1960s in two-way VHF mobile-radio applications!
Old 20th Jan 2019, 6:14 am   #10
Is that a water-filled lens?
EF50 were only just a pre-war development. There's an interesting tale of how Philips got them and their production equipment off to Britain only just ahead of the invading Nazis. They couldn't have been in any production TVs by then.
After the war they cropped up in RADAR IF strips which were handy for TV builders. I think this set has one at upper right, probably set up as a TRF for channel 1.
The CRT base is huge, is that a socket for the side-contact base of a VCR97 I-spy?
Radio Wrangler is online now
Old 20th Jan 2019, 10:49 am   #11
Heatercathodeshort
They were filled with liquid paraffin. I suspect there might have been some contamination when being filled in 1950!
I have many lenses but only one has turned that nasty colour.
I wonder what the picture was like? If discovered around the Portsmouth area it would have required a high aerial and pre amplifier. Rowridge came into operation in 1954 and this receiver pre dates it.
It may have been located high up on the South Downs, a significant advantage. I have read that a 1939 Cossor 1210 was working in Southampton with a three valve pre amp and a Murphy dealer with a V86C received excellent pictures with a huge aerial tower and pre amps at Ventnor on the Isle of Wight. [Murphy Service News] . John.
Old 20th Jan 2019, 10:57 am   #12
turretslug
turretslug's Avatar
I recall a provincial auction house from my teens where sets like this used to sporadically pass through with the distinctive "half a goldfish bowl" hanging off the front and was told that it contained paraffin- presumably, this would take longer to go "off" than water, although all the ones I recall were of various shades of that amber sort of colour, presumably as a result of slow oxidation. Perhaps there was also a refractive index consideration?
What would a fire safety official think of such a suspended incendiary attached to an occasionally fault-prone wooden box filled with hot-running components?
turretslug is offline
Old 20th Jan 2019, 11:46 am   #13
Peter.N.
Never seen one of those although I recognised the VCR97. many of the '50s sets used those liquid paraffin magnifiers the Bush TV12 and 22 particularly. Interesting find.
Peter
Peter.N. is offline
Old 20th Jan 2019, 5:36 pm   #14
Techman
Techman's Avatar
There's a bit of a difference between "liquid paraffin" and "paraffin oil" that you'd use in your lamp, stove or garden flame thrower
Techman is offline
Old 21st Jan 2019, 1:44 am   #15
Peter.N.
Liquid paraffin was used as a medicine to 'get things moving' you could say. There was a screw you could remove at the top rear to replace the liquid when it became discoloured as that one certainly has.
Peter
Peter.N. is offline
Old 21st Jan 2019, 9:42 am   #16
barrymagrec
As a kid I chucked one of these old magnifiers on to a bonfire - certainly didn`t burn like real paraffin.....
barrymagrec is offline
Old 21st Jan 2019, 3:48 pm   #17
turretslug
turretslug's Avatar
Aha, I was imagining something more like kerosene, i.e. somewhat searching, smelly and flammable!
Old 21st Jan 2019, 9:35 pm   #18
McMurdo
McMurdo's Avatar
I've seen that Premier advert many times in Practical Wireless adverts, nice to see one in the modern world
Kevin
McMurdo is offline
Old 22nd Jan 2019, 2:04 pm   #19
beery
beery's Avatar
Hi Matt,
I must admit I'm quite jealous. I've been after one for years having had a copy of the instructions for some time (don't ask me where they are!).
I hope you get the chance to restore it.
Andy
beery is offline
Old 22nd Jan 2019, 3:29 pm   #20
Barrick
Does the restoration job for something like that cost an arm and a leg?
Amazing set btw! I love it.
Barrick is offline
