Old 30th Jul 2021, 1:55 pm   #1
clockman
Smile AvoMinor History
Hi i have just acquired this little vintage AvoMinor from about 1955 and was wondering if any one has memories of this little meter made by the Automatic Coil Winder & Electrical Equipment Co Ltd Winder House Douglas Street London SW1 .It measures 2.45 inches wide 1.45 inches deep and is identical to its big brother the Avo 8 and is complete with the instructions for use on the back . I have fitted a 1.5 volt battery and it is in perfect condition and Accurate on all ranges including Ohms .it now sits on the shelf next to my vintage clocks of the same age now saved for evermore TAB
clockman is offline
Old 30th Jul 2021, 3:05 pm   #2
valveaudio
Default Re: AvoMinor History
Have a look here.
http://www.richardsradios.co.uk/avominordata.html
valveaudio is offline
Old 30th Jul 2021, 7:07 pm   #3
clockman
Smile Re: AvoMinor History
Thanks for the info Amazing loads of detail i did not realize they went back as far as 1935 the year i was born. TAB
clockman is offline
Old 30th Jul 2021, 7:32 pm   #4
Superscope
Depending on how much you want to get into Avo Minors,
a search on this very Forum will bring up quite a bit of info
as well, especially regarding Maintenance and Repairs.
We have at least one very Knowledgeable Avo Minor person
on here, and at least one for the DC Avo Minor.
Incidently, Avo Serial Numbers are always welcome over on the
"Avo Multimeter survey" Sticky Thread
Ian
Superscope is offline
Old 30th Jul 2021, 8:47 pm   #5
The Philpott
The Philpott's Avatar
One impressive thing about the DC Avominor is how light in weight it is. Even the glass is about 1mm (40 thou) thick. They are capable of collecting an impressive amount and assortment of grot in the terminals unless they've been boxed! There's no nickel plating in there so neglected purchases sometimes benefit from polishing.
Dave
The Philpott is offline
