28th Jul 2021, 9:34 am | #1 |
AVO valve tester question.
I have recently acquired this rather nice early AVO tester and data books, it works OK. Went through my collection of 6V6's yesterday with no issues however its left me scratching my head a bit with regards to 12AX7's, 12AU7's etc. I have the rotary switches sussed out (641 337 412) but not sure where to set the "Set mA/v" selector and the "screen" selector. Someone has hand written some settings in the data book but left the S.V and MA.v columns blank. Obviously they are double triodes so how do I check one side then the other?
28th Jul 2021, 11:46 am | #2 |
Re: Avo valve tester question
Hi - do you have an instruction manual? I have a 5Mb PDF of the military instruction manual I could email to you if you like? Basically in paragraph 71 it says "set the anode selector switch to A2 and repeat".
Cheers Chris |
28th Jul 2021, 12:01 pm | #3 |
I do have an original instruction manual for it plus a couple of valve data books but they are in very fragile condition so yes a downloadable one would be most handy. I am missing the full set of selector settings for 6AT6, ECC82, ECC83 and E180CC currently. The selector drum settings are fairly straightforward to work out its just the controls on the meter part of it that need clarifying.
28th Jul 2021, 12:22 pm | #4 |
I have done a quick jpeg of 3 of these 4 equivalents, and tried to attach the PDF which may be too big for this site in which case if you forward an email address I will post it there.
6AT6 = CV452, ECC82 = CV491, ECC83 = CV492, E180CC = not mentioned Cheers Chris |
28th Jul 2021, 12:27 pm | #5 |
28th Jul 2021, 12:45 pm | #6 |
Re: AVO valve tester question.
It's worth putting "avo valve tester manual errors" into the Search box at the top before you find errors the hard way.
This search also brings up a very useful AVO Valve Data Manual 23rd edition in OCR PDF format. |
28th Jul 2021, 2:26 pm | #7 |
Thanks chaps, getting my head round it now I think
28th Jul 2021, 3:15 pm | #8 |
Its worth noting that the "2 panel" AVO tester only goes up to a gm reading of 10, this can be problematical with valves such as EL84 which often go above 10.
Peter |
