9th Sep 2019, 1:37 am | #1 |
Early 1958 Bush SRP31 question update
Could the more experienced members of the group please help answer my question regarding the original 1958 SRP Bush record player.
When it comes to replacing the rectifier, what is the biggest difference between the original SRP31 chassis and the later model SRP31C/D Which diode and resistor is currently recommended for using in this early model? As I have *absolutely no prior experience* of updating and replacing a rectifier. Could anyone please provide/upload clear photographs to this thread as to precisely how this is to be done or PM me with the information. Many thanks. John. |
9th Sep 2019, 9:42 am | #2 |
Re: Early 1958 Bush SRP31 question update
I’m not sure of the difference between the two models.
The typical replacement components are: 1N4007 diode and a 330 ohm 5 watt resistor connected in series. The ht voltage is about 215 volts dc. Cheers John |
9th Sep 2019, 9:46 am | #3 |
I think they changed the record player deck in the later version, both amplifiers seem the same.
Mount those components John refers to on a tag strip making sure you connect the diode the correct way round. Keep the resistor away from other components it will get hot.
Frank |
9th Sep 2019, 9:49 am | #4 |
Further to my post, I took a look at the service manual and at the back it said that the SRP31c is identical electrically but with a slight difference in the cabinet and different record deck fitted.
Cheers John |
9th Sep 2019, 10:06 am | #5 | |
Here you go:- https://www.vintage-radio.net/forum/...d.php?t=153857
9th Sep 2019, 10:55 am | #6 |
Normally I remove the grey wire going from the transformer to the rectifier (usually grey) then mount the diode and resistor between the transformer tag where the grey wire was and the capacitor can’s tag nearest the edge of the chassis.
9th Sep 2019, 12:22 pm | #7 |
Be aware that there's quite a difference between the BUSH SRP31C and SRP31D.
Edward. |
9th Sep 2019, 1:39 pm | #8 |
Is that relevant to the OP's query?
9th Sep 2019, 2:56 pm | #9 |
Edward will you tell us the difference please, thank you.
Cheers John |
9th Sep 2019, 4:14 pm | #10 | |
/C 2x ECL83
Frank |
9th Sep 2019, 4:55 pm | #11 |
Thank you Frank.
Cheers John |
9th Sep 2019, 7:26 pm | #12 |
Also they employ a different autochanger and cartridge in each version.
Edward. |
9th Sep 2019, 8:20 pm | #13 |
Is the existing rectifier located in the same position as in the non-suffixed models? That's what's important to the OP who's seeking detailed instruction as to how to replace it.
See the thread linked to in post #5.
9th Sep 2019, 8:23 pm | #14 |
In this instance we're only concerned with the HT rectifier though, which is the same selenium unit. As said, replace it with a silicon diode and a resistor to bring the HT to approx the same. I used the same method as Michael in post 6, but the only requirement is a good constructional technique it's only two components.
Edit: crossed! |
9th Sep 2019, 8:40 pm | #15 |
This is info on the SRP31 and 31C, I don’t have under chassis layout information for the /D.
The differences described for the 31 and 31C are record deck and pickup cartridge. The amplifier is identical using ELC83 valves in push pull. The SRP31D with ECL86 valves has a similar upper chassis layout, I can’t confirm underside, be surprised if layout was a lot different.
Frank |
9th Sep 2019, 8:58 pm | #16 |
I guess we need a picture from the OP showing the existing rectifier and wiring.
I thought the OP had asked a simple question which merited a simple answer. How wrong I was, 16 posts and counting!
10th Sep 2019, 12:03 am | #17 |
The circuit is more or less the same between the two versions (ECL83/86) but the pin outs on the valves are different. I think ECL86 was more reliable.
Rectifier and smoothing circuits exactly the same on both. |
11th Sep 2019, 3:34 am | #18 |
