Old 21st Sep 2018, 9:25 am   #1
vampyretim
Default BUP40 transistor replacement for Quad II
I'm repairing a modern quad II. The Kt66's on one channel have failed and drawn a current that has fried a lot of components in the power supply and the output stage. It has also taken out the solid state phono preamp which has a BUP40 transistor across it's supply voltage. I can't seem to find a replacement BUP40 anywhere! Does anyone have one? Or can someone point me in the right direction?
I've successfully repaired the valve side of things, all output valves have been replaced with matched pairs and I have repaired the rest of the damage. The rest of the amp sounds great. It would seem ironic that it's the modern circuit that I'm having difficulty finding parts for.
Any help much appreciated.
Many thanks,
Tim.
vampyretim is offline
Old 21st Sep 2018, 10:21 am   #2
Craig Sawyers
Craig Sawyers's Avatar
Default Re: BUP40 transistor replacement for Quad II
Try contacting Quad service, which is still in Huntingdon.
Craig
Craig Sawyers is offline
Old 21st Sep 2018, 10:38 am   #3
Herald1360
Herald1360's Avatar
It looks like a PNP power transistor.
Probably not too difficult to sub.
https://alltransistors.com/transisto...ansistor=30043
Beware- apparent datasheet is for BUP400, an IGBT!
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 22nd Sep 2018, 6:45 pm   #4
Chris55000
Hi!
https://pdf1.alldatasheet.com/datash...ISC/BUP40.html
It's not easy to substitute because of the relatively high hFE and wide hFE range quoted, but see how you get on with the readily available BD140-16 first!
Chris Williams
Chris55000 is offline
Old 26th Sep 2018, 9:42 am   #5
vampyretim
Thanks Chris.
Old 29th Sep 2018, 11:37 am   #6
SteveCG
vampypetim - a quick thought. I thought modern Quad IIs used KT88 valves and not the KT66s (you mention in your opening post)used in the original 1950s design. Perhaps I'm wrong on this!
SteveCG is offline
Old 29th Sep 2018, 6:58 pm   #7
JohnM73
The current Quad II classic monoblock reproductions still use the KT66 (would love to see how the interior construction compares to the originals), as does the Quad II Classic Integrated. It's the Quad II Forty, Quad II Eighty which use the KT88s:
http://www.quad-hifi.co.uk/product.php?cid=7
Cheers,
John
JohnM73 is offline
Old 2nd Oct 2018, 1:05 pm   #8
SteveCG
Thanks, JohnM73, for the clarification.
SteveCG is offline
Old 2nd Oct 2018, 3:45 pm   #9
GrimJosef
Originally Posted by JohnM73 View Post
The current Quad II classic monoblock reproductions still use the KT66 (would love to see how the interior construction compares to the originals) ...
Google is your friend - they look like this
https://i.pinimg.com/originals/79/09...dcfe452973.jpg
The connectors have all changed and the wiring is up to modern standards. The circuit is similar but a few details have changed. The KT66 cathode bypass capacitor is now 47uF (was 25uF), the HT reservoir and smoothing capacitors are now larger - 32uF or 47uF I think (were 16uF) and there seems to be a bleed resistor on them which wasn't there originally. The metal-cased coupling capacitors between the EF86s and the KT66s have been replaced by plastic-bodied ones and it's nice to see that the stray capacitance to ground that the original metal case provided has now been replaced by small disc ceramics . There may be additional components around the rectifier - is that a thermistor designed to slow the heater warm-up (some modern KT66s seem to take a long time to warm up) and perhaps there's an inline fuse in the HT output from the rectifier ? Of course it's impossible to tell how the details of the modern transformers compare with the original ones.
Cheers,
GJ
http://www.ampregen.com
GrimJosef is offline
