Old 13th May 2021, 9:39 pm   #21
peter_sol
Default Re: Selga 405 audio problem.
Well done. Once again various contributers to this forum have helped you solve the puzzle.
peter_sol is offline
Old 13th May 2021, 10:18 pm   #22
Radio Scotland
Radio Scotland's Avatar
Definitely peter, I knew the problem was right under my nose, And i finally worked it out when you made the comment about running the centre tap to earth,
Help!! I've been electrocuted by a glass thing that glows
Radio Scotland is offline
Old 13th May 2021, 10:56 pm   #23
Radio Scotland
Begs the question of how the transformer broke free from the PCB But the rest of the radio is pristine
Old 16th May 2021, 3:01 pm   #24
Radio Scotland
I'm quite impressed by the sensitivity of this radio, It might have some design peculiarities and it isn't the best build quality, But it works well.
Thanks to peter sol for donating the output transformer, I came across an old post which states the output transformer spec for the 404 model, I'm presuming the 405 uses the same transformers.
Primary: 2 x 225 turns, 0.15mm wire, 7 Ohm
Secondary: 60 turns, 0.35mm wire, 0.6 Ohm
Jay
