| Vintage Computers Any vintage computer systems, calculators, video games etc., but with an emphasis on 1980s and earlier equipment. |
#41 |
Thanks Ian, much appreciated
![]() If theres any remaining doubt, I saved my KB+ source at every dev stage, before & after every command or feature was added... a full audit trail
#42 | |
Did you remove the bug in hexdump I found in kitbug in your own version(s)? The bug isn't that bad but won't display a dot when a character has the value 0x7F.
Greetings, Nick de PE1GOO |
#43 |
For those who don't already know, Craig has posted another interesting instalment:-
https://www.youtube.com/watch?v=ezwSMqDYGp0 |
#44 | |
As bugs go, its harmless ![]() Not sure what 'my own versions' means? KB+ isnt a version of anything
#45 |
For the benefit of recent arrivers and people like me with bad memories, could you give a brief summary of what KB+ is since there seems to be a degree of confusion about it?
#46 |
That would be a long post likely to need longer than the forum's edit window G
![]() I'm as baffled as yourself as to why there is confusion ![]() The shortform story: As you know in 1980 I built the Aitken SC/MP and added more ram and NS Kitbug in eprom. Kitbug has only three commands, two operate at the byte level - modify and type. It also has a 'Go' command which doesnt have an argument and so needs convoluted register settings before entering 'G'. This was very limiting and I began adding to and changing Kitbug, with a formatted memory dump, inline print, serial loader and more, all integrated into what I then called KitbugPlus, since by then it had moved on from its Kitbug roots and I'd several 2716's some plain Kitbug and some with additions and so used KB and KB+ on the labels to identify them. These same routines are still in the current version with little change from 1980. Later changes included an SPO256 driver (since dropped), baudot serial for RTTY, etc. When I restarted what was now 'retro computing' as a hobby I picked up KitbugPlus from where I'd left off, and adapted it to Karens PICL (which has some I/O & memory-map peculiarities). Mike used it for his 18877. Then I was asked by Kris to port it to the MGH board. Having a full & flexible memory map this meant I could further expand KitbugPlus and thats the version we have today but I want to emphasize this wasnt/isnt some triumph of software engineering, its just the result of a sub-average enthusiast tinkering in his shed over the decades. So KitbugPlus is my monitor for SC/MP hardware systems & emulators, currently with the following command set: Copy<U/D> CS Display xxxx Go xxxx List xxxx Modify xxxx Offset xxxx yyyy Regs Sload xxxx Type xxxx Nibl C is an 'intelligent' copy in that it can handle overlapping blocks of memory, but can also 'fill'. CS is clear screen, D is the usual tabulated memory display in hex/ascii, G runs a program from address xxxx, L lists in 'instruction-length-aware' format, M is modify, O calculates the relative jump offset to jump from address x to y, R displays the registers, S is the fast serial loader (2400 no delays), T is a byte by byte memory dump. It has inline print and you can preset register contents before 'G xxxx' if required. N command for NIBL isnt there if its not applicable. It normally lives in page zero so it runs from reset, and includes an option for a boot menu ( KB+ / NIBLE / NIBLFP ) but on the PICL its a limited subset run from 7C00 in NVram. There are similar reduced versions for the micro-introkit etc. The full one is 1700 decimal bytes, and the same 'full' image runs on the MGH8060, MGH8060GAL and SCMPII-Max without changes and on Ron Dekker's board with a memory-map change. Theres a full document within the MGH8060GAL zip on philg.uk but thats it in an oversized nutshell ![]() Cheers Phil Last edited by Phil__G; 13th Sep 2025 at 2:24 pm. |
#47 | |
I checked and for some reason the KB+ overview wasnt in the MGH8060GAL zip, I've added it now. The file is called "kitbugplus_scmp.pdf" within https://mccrash-racing.co.uk/philg/scmp/mgh8060gal_source.zip and it was last updated Nov '23 Cheers Phil |
#48 | |
Hello World, It's Craig. Retired, but with passion and a sense of urgency. |
#49 |
Part of the confusion was my fault, sorry everyone, but I think we're all deconfused now
#50 |
Epic post, Phil. I was expecting something along the lines of
"Kitbug+ was an enhanced alternative to Kitbug which I wrote some time ago." I think it is fair to say we have the definitive answer now, thanks for taking the time to set that out. Incidentally, if composing a long message which is likely to contain a high number of missed errors I sometimes compose it in Notepad and then cut and paste it into the forum's editor afterwards. It's just a shame I don't follow my own advice more often, hence the frequent last minute edits to my posts. |
#51 |
I do like NIBL, it has some peculiarities but you soon get used to them.
For example if you want a new line, in conventional BASIC you'd just say PRINT whereas in NIBL you have to use PRINT"" When PRINTing a mix of text and variables, each part needs it own separate PRINT though you can suppress newlines for continuity. If you want an INPUT to have a text prompt, that needs to be done with a PRINT. Internally its uppercase-only, though you can print lower case. Conventionally the abbreviation for PRINT is ? but in NIBL its PR. The @ for directly reading & writing memory is like conventional PEEK & POKE, and any numbers or variables over 32768 will go negative! (n-65536) ![]() https://www.mccrash-racing.co.uk/philg/scmp/SCMPDLY.NIB Given the resources the string handling is very flexible (in that you have to do it all yourself!) and mixing in some M/C is easy with TOP & LINK ![]() NIBL is delightfully different, its really cute!
#52 |
Yes, I like the SC/MP assembly code. After 45 years I still do remember the full instruction set of it. Yes it was my first computer ever.
![]() But I agree NIBL is also cute it is simple but you can do a lot with it.
#53 |
I use a form of hex that I call PEX which is much faster for NIBL to handle as theres no 'add 7 if above 9' hex conversion which really slows NIBL down.
The PEX lines live in REM statements at the start of the NIBL program and can be seen in BASYS and the disassembler in the KO2019 package. PEX looks like this: Code:
1 REM @HLBCACELBC@CALD@HLJNJ@FMDB@ILOKLDDCHO@@@FMDB@IL 2 REM OBLDHNHO@@@FMDB@IL@BIH@BLD@AAO@AAM@AKJNJILNKD@LM 3 REM @ALDKMHO@@@FMDB@ILLM@FMDB@IHOKCO@HLDKICCLD@OCGLB 4 REM BNALALALAL@BODOFID@DODCJI@@BODD@COLBBNMD@O@BODOF 5 REM ID@DODCJI@@BODD@COLD@ICGLDFOCCCO@@@@@@@@@@@@@@@@ and S to where the actual PEX characters begin. On page one its later because thats where NIBL variables etc are stored. Code:
M=#7F80:S=#000A P=@#1012:@#1041=P*16:IF P=1 S=#1128 Code:
FOR L=0 TO 4:FOR B=0 TO 46 STEP 2:A=S+B+L*57 Code:
X=(@A) AND 15:Y=(@(A+1)) AND 15:Z=(16*X)+Y Code:
@M=Z:M=M+1:NEXT B:NEXT L In the KO2019 package, any hex output from BASYS or from the Disassembler was very slow using NIBL directly, so thats where M/C comes in, and theres also a serial fastloader in the example above (identical code is used in basys & the disassembler). Loading progs into the NVram projects only needs to be done once anyway, for example in the PICLv2 package theres a PEX loader to install a subset of KitbugPlus, again it only needs to be run once when using NVram so its 'fast enough' I've a few utils for creating PEX from binaries and from Intel hex, all easy peasy as basically its just text Theres not much you can't achieve with NIBL & a bit of SC/MP m/c
#54 |
I wrote some ramless diagnostic code for my SC/MP Nibbler project and I am wondering how universal it is, but the Nibbler is the only SC/MP board that I have. Baud rate is 2400 for 4MHz scamp II. It only requires the TxD be on flag 0 (inverted) or flag 1 (not inverted), the RxD be on Sense B, and the ROM located at 0x0000. If someone has a MK14 or other SC/MP platform on their bench and time to burn an eprom and try it out, I would be interested if everything (or anything) works. To get to the command prompt, Sense A and SIN need to be at 0V at reset, or else it will enter low level infinite loops.
.asm , .lst, .hex, and users guide are at the link below. Now I am off to port Phil’s resident monitor over to the Nibbler. Thanks -Craig https://bitsofthegoldenage.org/download/sc-mp-ramless-diagnostic-utility/
#55 |
Here ya go:
https://youtu.be/C5trHgr8qKU Dont know what I'm doing as I havnet read the doc yet, will do that later ![]() One thing I noticed, the 'map ram' scan started at 0F00, where my RAM starts at 0800 immediately after KB+ yet a manual ram test from 0800 seems ok Most likely me, what we used to call in Post Office Telephones, "Subs Misop" ![]() I'm most impressed with your ramless serial Craig! Cheers - Phil EDIT: forgot to say I took the on-reset SIN and SENSE tests out to make it go straight into the menu . Last edited by Phil__G; 1st Oct 2025 at 12:10 pm. |
#56 | |
Code:
LDI 0FH ;SET P2 TO STARTING POINT
XPAH P2
LDI 00H
XPAL P2
MAP_TEST:
0000 to 07FF is rom (normally KB+) 0800 to 0FFF is ram normally for KB+ scratchpad, stacks, vars etc) 1000 to 1FFF is ROM (normally NIBL-E) 2000 to 2FFF is ram (NIBL-E page 2 etc) 3000 to 3FFF is rom (normally page3.sys) 4000 to 7FFF is ram (the bulk of r/w memory) 8000 to FFFF is rom (NIBL-E toolkit, NIBL-FP etc) Last edited by Phil__G; 1st Oct 2025 at 2:14 pm. |
#57 |
Just a suggestion Craig, the Map ram command tests every single byte to see if it can be written, but since its unlikely that address decoding is more granular than 256 bytes, you could just increment the pointer MSB through memory and leave the LSB alone (doesnt matter what it holds) which would print out the memory map much more quickly (presently takes 25 minutes or so). The 'T' command gives your full memory test so I just wondered if 'M' needs to be so granular? Just a thought...
#58 |
Been following these SC/MP threads with interest, the TeleKit was very informative.
The Scrumpi book was interesting as I have built a similar version using TIL311 Hex Displays for the ADDR and DATA lines. Ive also built on breadboard a HEX keypad using a PIC16F628 that replaces the 8 databit switches, making it easier (and faster) to enter code . I'll write it up and post here if there is interest. Following links to the 'Nibbler' on YouTube took me to this link https://bitsofthegoldenage.org/download/sc-mp-ramless-diagnostic-utility/ where 'Hello World' has developed and published a RAMless diagnostic for SC/MP that only needs a Serial port connected to SB and F0 as normal and runs on a PuTTY at 1200 baud. |
#59 | |
I know you love saving a few bytes Craig and diags is exactly a full 2k - here's nine redundant LDE's in the command loop:
Code:
LDI /PUTS-1 ;P3 IS PUT STRING
XPAH P3
LDI #PUTS-1
XPAL P3
LDE
XRI '?' ;IS IT ?
JZ CMD_ENTER ;YES, DISPLAY COMMANDS
XRI 'V'!'?' ;IS IT A V?
JZ CMD_V ;VERSION
XRI 'A'!'V' ;IS IT AN A?
JZ CMD_A ;ADDRESS DECODER TEST
XRI 'F'!'A' ;IS IT AN F?
JZ CMD_F ;FLAG SEQUENCE
XRI 'M'!'F' ;IS IT AN M?
JZ CMD_M ;MAP MEMORY
XRI 'I'!'M' ;IS IT AN I?
JZ CMD_I ;INSTRUCTION FETCH TEST
XRI 'R'!'I' ;IS IT AN R?
JZ CMD_R ;READ INPUTS TEST
XRI 'S'!'R' ;IS IT AN S?
JZ CMD_S ;STICKY BIT TEST
XRI 'T'!'S' ;IS IT AN T?
JZ CMD_T ;TEST RAM
XRI 'W'!'T' ;IS IT AN W?
JZ CMD_W ;WRITE/READ RAM
LDI /CMD_MSG2 ;MESSAGE IN P2
XPAH P2
LDI #CMD_MSG2
XPAL P2
XPPC P3
JMP CMD_PROMPT ; NO, TRY AGAIN
![]() Quote:
Your keypad sounds similar to my Cosmac Elf one! Yes please post it, the more the merrier!
#60 | |
Thanks for taking the time to look at this Phil. Yes, I accidentally left the start of the ram test near to]he top of the ROM. I put it there to speed up the test but forgot to change it to zero I will address that. I need to upload a new version because I added a halt test.
