3rd Aug 2022, 7:07 pm | #1 |
Workshop clearance part 2
Hi folks, after the interest my last post generated I thought people might be interested in other items I've found. Some of these I can't identify
3rd Aug 2022, 8:15 pm | #2 |
Re: Workshop clearance part 2
Hi Some decent modern (by our standards) test equipment there.
There is a collection of digital integrated circuits from possibly early computers A resistance test set No idea what the blue box is#A test pattern generator for colour TV A capacitance test meter Cheers, Ed |
3rd Aug 2022, 9:10 pm | #3 |
The second item is an analogue insulation and continuity meter. A specification can be seen here; https://testequipment.center/Product...ions-4B2AD.pdf
It has a wide range of insulation test voltages and a maximum value of 100Gohms. The maximum continuity test current is 60mA at 300mV against 200mA at 4 - 24V required by BS61557-4 for electrical testing to BS7671. PMM |
3rd Aug 2022, 9:13 pm | #4 |
Hi
Are you selling the colour bar gen?. Please pm me if you are selling. Many thanks. Bob
Bob, BVWS member |
4th Aug 2022, 12:59 pm | #5 |
Thanks for all the info - I will take a closer look at the blue box
4th Aug 2022, 1:11 pm | #6 |
Some more that might be of interest, I've yet to look at the paper boxes but I will post anything interesting.
4th Aug 2022, 6:58 pm | #7 |
One mystery solved - the blue box is a clock (I got brave and plugged it in) I've attached a picture of the internal workings - I guess it might have been a kit as the box isn't a thing of beauty.
5th Aug 2022, 7:03 am | #8 |
Some nice tools there, the long red thing that looks like Harry Potter's wand on steroids is a high voltage probe, pic 2 wot it says on the leaflet, isolated mains supply, little bench drill press,some sort of TV arial adaptor kit maybe.
Andy.
5th Aug 2022, 12:12 pm | #9 |
The last one is a Greenpar inter series adaptor kit. Nice things. The spanners are used to screw the various halves together.
5th Aug 2022, 5:16 pm | #10 |
In the chips I see a couple of FDD controllers, one WD1772 and another an intel 8271 as used in the BBC model B - just add DFS EPROM and you have a FDD capable model B.
Also CPUs 6502, 65C02, 6809 Also a uPD7002C 12 bit analogue to digital converter, again used in BBC model B in the analogue / joystick interface. I would hope some of these would be of interest to someone. |
8th Aug 2022, 12:33 pm | #11 |
These items are no longer available
