30th Jul 2022, 5:24 pm | #1 |
Battery-heater subminiature diodes.
These never seem to have been a 'thing' - I'm thinking here of the little double-ended glass types for use at VHF.
The EA50 allegedly had a rare sibling the DA50 but its heater-consumption was rather high; it seems a lot of applications like RF field-strength-indicators/wavemeters used a diode-strapped pentode like the 1S5 or 1T4. Which seems wasteful particularly in the context of WWII usage. So why I wonder was there never a little B3-style VHF glass diode that would take, let's say, 25mA at 1.4V and work up to a couple of hundred MHz?
30th Jul 2022, 5:56 pm | #2 |
Re: Battery-heater subminiature diodes.
This was apparently designed for radar use, but not quite what you wre looking for.
http://www.r-type.org/exhib/acl0322.htm PMM |
30th Jul 2022, 6:16 pm | #3 |
4V 0.2A heater... yes it's not going to work well in a hand-held field-strength-meter/wavemeter powered by a single flashlight battery...
The DA50 took 0.3A at 1.2V so would still drain a single battery rather fast. The later B7G DA101 took only 50mA at 1.25V so is closer to my idea. https://www.radiomuseum.org/tubes/tube_da101.html Of course all were obsoleted in the early-50s with the coming of cheap Germanium diodes.
30th Jul 2022, 6:56 pm | #4 |
Just the other day I came across a EA50 amongst several TV/radio valves and wondered what use could be made of it.
For those that haven't seen one please see attached pic. Regards, Symon |
30th Jul 2022, 7:05 pm | #5 |
I wonder if you could use it in a perversely-retro valve-powered crystal-set?
The EA50 was used extensively as sound- and vision-demodulators and peak-limiters [to remove car-ignition/motor-commutator spikes which otherwise caused crackles and transverse stripes of white-dots] in the first generation of TV receivers; it also found service in a whole bunch of WWII RADAR systems. I guess it was equivalent to the likes of the OA81/1N34A Germanium-diodes which followed. I've got an EA50 somewhere, along with a 'low-loss' ceramic holder for it.
30th Jul 2022, 7:11 pm | #6 |
The EA50 and CV equivalent were sold off in huge quantities after the war, and apparently cost pennies for dozens. They turn up in all sorts of 50s hobbyist gear and projects. They can be used as HT rectifiers if the current is low - I have a 2 valve sig gen that uses one (all the other components look government surplus too). It doesn't use a holder, it's just soldered in.
30th Jul 2022, 7:32 pm | #7 |
30th Jul 2022, 8:56 pm | #8 |
There's the 1A3 in B7G, 1.4V 150mA... but it is indirectly heated so you have the luxury of a floating cathode!
30th Jul 2022, 11:34 pm | #9 |
Are not EA50's used as rectifiers in a multitude of VTVM's ?. In the probe itself.
Joe |
1st Aug 2022, 5:36 pm | #10 | |
The ones I encountered usually fed the probe-tip to the EA50 anode through a high-voltage-rated low-value capacitor - typically a few tens of pF - which was calculated to work with the EA50's stray-capacitance as a RF potential-divider. Worked well, up to around 50MHz.
