6th Dec 2013, 9:46 am | #1 |
Trimphone. Broken regulator No.7
Hi Guys,
last night I was changing the line cord on a Trimphone I recently bought, and somehow I managed to break the connector off of the Regulator No 7 (The large blue cylinder, which prevents I believe line noise) Does anyone know where I can get a replacement?? (I scoured ebay the internet to no avail last night) Or Is there something that I can purchase (Maplins??) that I can use to replace the regulator? Or Is this something I will have to try to repair myself (bear in mind I have zero soldering skills) and is this something I could do myself Any help, as ever, greatly appreciated |
6th Dec 2013, 10:52 am | #2 |
Re: Broken Trimphone regulator No.7
This site suggests it was a mod for use on short lines, so unless you're very close to the exchange, you should be OK without it, I'd guess.
http://www.samhallas.co.uk/collectio..._trimphone.htm Nick |
6th Dec 2013, 11:11 am | #3 |
Max, you have a PM
6th Dec 2013, 11:25 am | #4 |
Thanks Guys,
PM back AndiiT |
6th Dec 2013, 9:06 pm | #5 |
The regulator could be replaced by something as simple as a resistor, The regulator was some kind of self adjusting shunt limiting the current trough the carbon transmitter. I would try with a simple 220 ohms 1/2 watts resistor. If the signal level from the transmitter drops too much, try 330 ohms.
dsk |
11th Dec 2013, 6:19 pm | #6 |
GPO 772 Trimphone Trouble
Hi Guys,
Just finished working on my latest GPO 772 Trimphone, plugged it in, and nothing, it's dead as a dodo!! It's wired thus - Dial Orange T8 Blue T2 Brown T3 Grey T1 Pink T10 Line Red T1 White T8 Green T2 Blue T3 Handset White T19 Green T15 Red T8 Blue T6 Straps 5-6-7 16-17-18-19 (These straps were as it came, which I assume was when it worked) I know I'm missing the regulator (the Blue One, No.7?) But would this stop the phone working, without the regulator? Any ideas? Have I mixed the wiring up?? I'm so frustrated, so much so that I can't tell you how much!! Last edited by AC/HL; 11th Dec 2013 at 6:31 pm. Reason: Images uploaded as attachments |
11th Dec 2013, 6:30 pm | #7 |
Re: Trimphone. Broken regulator No.7
If you want your phone to work without a regulator, you'll need to link together certain points.
This link points to the circuit for a Tele 706, but the points to be linked ie B, C and D are the same:- http://www.samhallas.co.uk/repositor.../0000/N806.pdf If your phone is on a short line, you may find it rather loud owing to the missing/bypassed regulator.
11th Dec 2013, 9:08 pm | #8 |
I have probably misunderstood where the fault are. Graham knows British telephones much better than I do. My last post in this thread was referring to a unit with only 2 contact points. This unit was put as a shunt of the transmitter in hence to reduce noise. The regulator in the link are a more complex circuit.
dsk |
12th Dec 2013, 2:44 pm | #9 |
The thing DSK is referring to is just a simple device which can be replaced with a pair of back-to-back silicon diodes such as 1N4007.
12th Dec 2013, 3:24 pm | #10 |
Indeed. The GPO designation was Rectifier Element No. 205.
It was fitted across the receiver (not the transmitter as stated) and served to suppress loud clicks.
12th Dec 2013, 5:35 pm | #11 |
Re: GPO 772 Trimphone Trouble
In a nutshell yes! you appeared to have muddled up the handset wiring with the line cord wiring.
Wire the handset cord as follows - White - T10 Red - T1 Green - T2 Blue - T3 Strap T4 - T5 - T6 - T7 Strap T16 - T17 - T18 - T19 Wire your line cord as follows (presuming it is a four wire cord with standard colouring, if not let us know) White - T18 Red - T8, ensuring that the orange lead from the dial is also connected to this point Blue - T5 Green (which is spare and not used) - T15 Try that and let us know if you experiencing any ringing problems on an incoming call and we'll advise further Andrew |
12th Dec 2013, 6:05 pm | #12 |
Sorry, but I confused Regulator with Regulator No.7.
What DSK says in post #5 is correct. Ignore my post #7.
16th Dec 2013, 7:23 pm | #13 |
Hi Guys, Well it works now. Although the only problem is speech & sound are both very very very faint, almost to the point of being inaudible.
Could I have wired the microphone/receiver in the handset up incorrectly?? Or if I had done this would it just not work at all?? |
17th Dec 2013, 5:51 pm | #14 |
Hi, the inaudible speech will probably be due to the transmitter inserts carbon granules having dried up over time. The only option is replacement but most inserts will be well past their useful capacity these days. If so minded you may be able to modify the handset to take the insides of a transmitter no.21 but this isn't an easy task.
Ensure that the handset blue and white wires go to the transmitter and terminals T3/T10 in the telephone, and the red and green wires to the receiver and terminals T1/T2. Regards Andrew |
17th Dec 2013, 9:55 pm | #15 |
It "sounds" strange.
This are a relatively new phone. I guess it should be possible to figure out whats wrong. The wiring diagram: http://tinyurl.com/18r are quite complex, but to go over the connections and look after if it is as in the diagram should be a minor job. Maybe even go back to the original ringer wiring, and later modify to UK outlet standard (if needed) dsk PS Transmitter element, and receiver element in series direct to the line should indicate if these two elements are OK DS |
