27th Jan 2022, 11:01 am | #1 |
PYE P76F Wave Change
The wave changer dial indicator slips on its spindle very easily. It seems to be held on the spindle by the cord. Is this correct? When changing wavebands the dial slips and eventually indicates the wrong band. Should the plastic dial be held in place by any other means other than the cord?. Help appreciated. Thanks
27th Jan 2022, 4:39 pm | #2 |
Re: PYE P76F Wave Change
Quick update. When wave switch in short wave position there is zero tension on spring holding one end of drive cord. Spring tension increases as switch moved to G position. Anyone know what the correct tension should be?
27th Jan 2022, 5:05 pm | #3 |
From the manufactures service sheet available above.
https://www.service-data.com/product...11/6662/m15211 Cheers Mike T
27th Jan 2022, 6:32 pm | #4 |
Mike I have the service sheet which shows route of cord but nothing about correct tension. Also should it be silicon lubricated or wax. Or dry
27th Jan 2022, 6:52 pm | #5 |
Hi, I don't think that there is a specific tension as such, but with mine I simply adjusted it so that the spring only just held the wire taught at the most relaxed position (SW). The indicator should of course be able to rotate freely on it's spindle, but I can't see any need to apply wax or silicone to the wire.
It is possible that the wire might have stretched slightly, so it may be a good idea to check the length according to the data rather than alter the actual spring.
Andrew Last edited by PYE 405; 27th Jan 2022 at 7:13 pm. |
27th Jan 2022, 7:23 pm | #6 |
Just to add to the above, I do believe there is a small notch that the wire passes through on the plastic indicator shaft. This probably serves as a securing point, but if worn, perhaps a very small dab of glue may help to keep the indicator from slipping due to the action of abrupt switch rotation.
Andrew |
27th Jan 2022, 9:00 pm | #7 |
Andrew, thanks for the info. My cord is not going through any notch on the plastic dial it's just wrapped around the dial
27th Jan 2022, 9:56 pm | #8 |
If your set has a cord instead of wire, then perhaps it was replaced I wonder. It could have been fitted from new though, especially as there is no notch in the indicator shaft.
In that case, a waxed cord might offer better grip than one without.
Andrew |
27th Jan 2022, 11:26 pm | #9 |
Andrew there is a notch just that the cord isn't going through it. It is now. Also it is cord not wire. Thanks for the info. Ken
9th Feb 2022, 10:18 am | #10 |
Update re wavechange switch it appears the relaxed position is not Shortwave on my set BUT G. Bluetooth works through the Shortwave selection and Longwave is TB.!!
9th Feb 2022, 1:32 pm | #11 |
Take a look at your other post, which I answered.
John |
11th Feb 2022, 10:11 am | #12 |
Thanks for reply. Problem due to cord wound back to front.
