Old 5th Apr 2019, 8:41 am   #21
Boater Sam
Boater Sam's Avatar
Default Re: Coil winding advice
Correct.
Winding with heavy wire off the end of the spool you finish up with the spool climbing onto the bench!
I was told that off the end was normal with fine wire, my old wooden reels are rounded and very smooth and polished on the ends precisely for that reason.
Boater Sam.
BVWS Member
Boater Sam is offline   Reply With Quote
Old 5th Apr 2019, 5:48 pm   #22
kernowcam
Just trying to test solder the old coil and new wire I have. The old on 400c seems to burn coating off fine, the new does not seem to want to play ball. Any suggestions please?
kernowcam is offline   Reply With Quote
Old 5th Apr 2019, 6:28 pm   #23
kalee20
What is the type of enamel on your wire? Post a photo of the label if in doubt. Fingers crossed you don't have high temperature or a non-solderable grade!
Old 5th Apr 2019, 6:42 pm   #24
kernowcam
No idea I am afraid 14 m of wire given to me!
May have to scratch it back!
Old 5th Apr 2019, 10:21 pm   #25
kalee20
I can sort some solderable 0.04mm wire for you, if you PM me your address.
Old 6th Apr 2019, 8:03 am   #26
kernowcam
Thanks , very kind of you.
This has become a major challenge now not to be beaten.
I was trying to re solder the hair spring to the pivot yesterday. Very difficult to get the spring on at just the right angle, i.e. Horizontal.
I was wondering if a small card disc with a hole may work?
Old 6th Apr 2019, 9:10 am   #27
Boater Sam
Boater Sam's Avatar
Stick it with superglue first?
Boater Sam.
BVWS Member
