Old 18th Feb 2017, 11:31 pm   #61
G0HZU_JMR
Default Re: CB squelch problem
The other option is to produce a laminated tool made to a drawing.
In the past I've made tools for things like this from a suitable piece of FR4 PCB material and a CNC router. You could either make a C spanner in FR4 or just mill a flat circle with the 4 teeth and then solder a vertical 'wrench' section to it made from flat brass folded into a tube and then put holes in the tube to make a wrench like a box spanner.
FR4 material is quite strong and it's going to be much less likely to mark or scratch the soft metal used in that mic socket body
I made a focus tool for my thermal camera like this a couple of years ago using PCB material. This one was an early attempt and it worked really well. It had to be 'very' accurate for all of those teeth to engage exactly with the focus wheel inside the camera lens. Obviously, this one has the teeth on the outer face but it could easily be milled for just 4 teeth on the inner face. I ended up making one like in the second image as this was easier to hold/use once it had a suitable lever on the end.
The other option would be to make one with a 3D printer? It might be strong enough?
ID:	137837   Click image for larger version
Regards, Jeremy G0HZU
G0HZU_JMR is offline
Old 19th Feb 2017, 12:44 am   #62
Damo666
Nice suggestions guys, cheers.
I'll first try some long nose pliers with a rag on the tips to avoid damaging the surrounding plastic or metal, but if I fail miserably with these, I've found one of those "camera lens adjustable wrenches" on eBay for £6 - so it's not a big investment, and it might come in handy in the future.
If I buy the tool it'll be coming from China, as the ones available in the UK are twice the price +. I'm patient & the CB is working well apart from this niggle, so all's good until it arrives in ~2 weeks.
Damo666 is offline
