19th May 2022, 1:53 pm | #1 |
Ferguson 208UL Aerial?
Hi - I recently got one of these, supposedly not working. After re-attaching a wire in the mains plug, I was hopeful, but damn, not a sound!
After a while I had a brainwave, switched it on again and this time let it warm up...! I'd forgetten about that! Took me back decades! Anyway, it worked but was very weak. So I stuffed one end of a long (5ft or so) wire into the socket on the back. There was a slight improvement, but not as much as when I gripped the socketed end of the wire in my fingers. It was then listenable-to, but still was distorted, and only would receive a couple of stations. My question is, what should I do to give it a decent aerial? Apparently, a wire is supposed to be wound round the 4 tabs on the back, but what kind of wire, and how many turns, I don't know. Also, the socket only has one connection. Is that normal? In fact, see the pic, the word "Aerial" is actually nearer to the little notch in the back cover than the socket. Is that something? Assuming it will work with a good signal, what kind of aerial would it like, and where to connect it? Thanks very much for any help. Graham Rounce London E2 |
19th May 2022, 2:14 pm | #2 |
Re: Ferguson 208UL Aerial?
It looks wrong to me - the 208UL should have a flying lead coming out from the little notch, which you refer to. Someone's been modifying it!
It's a simple radio this is, a 'short superhet' and as such is a bit lacking in gain. Despite this, it's a really cracking performer, thanks to good front-end design with far fewer compromises than many other sets. The four tabs on the back, by the way, are just to wind the aerial and the mains lead around, when carrying the radio (it's a transportable). |
19th May 2022, 4:46 pm | #3 |
Ah, I see!
Someone has fitted the socket and connected it up to what was the flying lead. That seems sensible. Shouldn't cause any problems? So I'm back to a wire plugged into that socket. Is it a case of the longer the better, and the higher the better? Any old wire? Thanks again, |
20th May 2022, 11:51 am | #4 |
Well, yes longer, high if possible and any old wire.
Edward. |
21st May 2022, 9:25 pm | #5 |
Anyone else think a 208UL should really have a Luxemburg button
-- Graham. G3ZVT |
3rd Jun 2022, 12:49 am | #6 |
Edward: Will do, then. Thanks
3rd Jun 2022, 11:01 am | #7 | |
My question is.....has this set been restored in any way? A poor aerial will not usually cause distortion BUT leaky capacitors will! As it's been identified as a short superhet, the usual and very damaging (if leaky) audio coupling capacitor will not be present (at least not to cause damage) but there are still capacitors that will probably require changing. If no work has been done then there are some checks and probable repairs that need to be made before it can be used safely and reliably.
1st Jul 2022, 10:25 am | #8 |
Hi - I'm a bit bored with this now, and it's taking up space. Does any *longstanding member* want to take it away? Bethnal Green. Please respond here in the first instance. The above responders come first!
