16th Apr 2022, 12:03 pm | #41 |
Location: Dungannon, County Tyrone, Northern Ireland, UK.
Re: 1936 Marconiphone 365 Radiogram
I left the rectifier in position and removed the rest of the valves as suggested by PJL.
I now have HT voltage of 160v at both pins of rectifier, 97v at anode of V4 and 117v at anode of V5. Lamp limiter in place and very dim. I guess the next logical thing to do is to replace 1 valve at a time and see what happens? |
16th Apr 2022, 12:28 pm | #42 |
Manufacturers circuit from this website.
16th Apr 2022, 1:50 pm | #43 |
What is the wattage of the bulb you are using in the liimiter?
Have you replaced any of the capacitors? We can work out the HT current if you measure the DC voltage on C37 (8uF) and C38 (8uF). I am working from Trader 720 as it is the only one on my CD. |
16th Apr 2022, 2:03 pm | #44 |
Manufacturer's sheet attached.
16th Apr 2022, 4:18 pm | #45 |
OK, WE HAVE SMOKE! While taking the readings that PJL suggested at C37 & C39 (162V @ 190V respectively) I inadvertently when switching the power supply off switched the lamp limiter off leaving the set on full power.
In very few seconds I had smoke from what would be the underside of the chassis. In my haste to switch off I did not see where said smoke came from however my nose leads me to R11/ R13 area and one of these two resistors (I think from chassis photo R11) looks burnt in the middle. All valves were removed at the time apart from the rectifier. The bulb in the lamp limiter is 60W and no capacitors have been replaced apart from C37 & C39 (C67 & C68) although I do intend to replace C28 (C81). C37/C67 is 16mf C39/C68 8mf. Previous to this I had replaced the valves one at a time with the rectifier in place. V1,V4 and V5 lamp limiter stayed dim. However V2 and V3 caused the limiter to brighten considerably. I noticed that as each valve was replaced the voltage dropped away. Any suggestions? |
16th Apr 2022, 6:00 pm | #46 |
Running with just the rectifier is not recommended on a set like this as the HT will go VERY high without the voltage drop from the field coil.
Lots of leaky capacitors I suspect. C8 would make R11 burn up so that needs replacing. Check the value of R11 and replace if over +/-25% of intended value. C36 and C38 need replacing as they sit across HT. C40 needs to be replaced or it can be disconnected. There are 3 audio coupling capacitors that will need replacing, C28, C29 and C30. I suggest we continue as we were - with the lamp limiter! Replace these capacitors and switch on with all valves in and measure HT again. |
16th Apr 2022, 10:20 pm | #47 |
Thank you StationX for Part of manufacturers service sheet.
John |
17th Apr 2022, 12:04 am | #48 |
It looks like R11 on the Trader sheet feeds C6 which is the 0.1uF V1 anode decoupling capacitor.
C6 needs to be changed. It may only break down when there is a high voltage on it. Any waxed paper capacitor that has high voltage on it must be changed to prevent expensive damage. That means C10, C18, C27 to C30, C36 to C38 and C40. C3, C19 and C25 need to be reformed or replaced. |
18th Apr 2022, 11:16 am | #49 |
I was press ganged yesterday by "she who must be obeyed" (Rumpole or Arthur Daley?) into visiting the grandchildren. I'll check what stock I have and order up what's needed to replace all waxed paper capacitors.
There are some black rectangular plastic type capacitors which are screwed to the chassis. Do these give trouble? I had hoped to get HT up and running and some output so that I could check my work one capacitor at a time. I have been frustrated in the past by changing all caps at once only to find the set dead and then have to go back over my work. R11 gives a reading of 740 ohms (should be 1000) First time I have had smoke so lamp limiter switching arrangement WILL be changed. Switches at least 1 meter apart! |
18th Apr 2022, 1:42 pm | #50 |
Without jumping the gun the rectifier may be usable up to a point.
John |
18th Apr 2022, 3:28 pm | #51 |
If R11 was getting hot it could easily be passing 20mA, probably more.
The cumulative effect of several leaking capacitors may be overloading the HT rectifier and dragging the HT voltage down. |
19th Apr 2022, 5:53 am | #52 |
Hi Black rectangular cap types are normally mica types and usually lower than 5000pf, not normally faulty, but worth a check. Sometimes odd values when used in tuned circuits so if replaved take care
Ed |
19th Apr 2022, 11:58 am | #53 |
My eyesight is not so good... yes C6 and not C8 for R11. Just checked the others I quoted and they are correct. As Silicon has said, all paper caps will probably need replacing although you might get it to work with partial replacement.
19th Apr 2022, 12:31 pm | #54 |
Thanks again to all for your interest and help.
The black rectangular caps are stacked two at a time and screwed to the chassis. They are C28, C29,C32 and C33. I realise "that capacitor" or should it be "those capacitors" are in that group so should I change them? I can replace the paper C30 from stock. I can also change several other paper caps including C6 (thanks on clarity) and R11 from stock. So next step I think is to change what I can and try for HT again (with new switching arrangement on limiter!) to see what happens. I think I will have to remove chassis from the cabinet (I have been trying to keep it all in one piece at this stage) as some caps are buried in the gubbins. |
25th Apr 2022, 8:41 pm | #55 | |
no change after the recap and limiter is still glowing much the same as before. I then did what Michael suggested above and with link 2/7 removed and output valve removed I get a reading of 312 V HT at the rectifier and at the anode of V5. Limiter has a mild glow. All electrolytic caps have been replaced however, the three that should be 4uF (C62,C69 and C72) are 2uF, 50uF and 16uF and Radio Spares replacements. I replaced these with equivalents. Anybody got suggestions? There is no sound from the speaker since day one. |
25th Apr 2022, 10:01 pm | #56 |
Try the set with just link 2/7 removed and with just V5 removed to check which is causing the HT to drop. All other valves can be left in place.
25th Apr 2022, 10:40 pm | #57 |
Thanks for the reply Station X. With V5 in place and link 2/7 removed I have 280V HT (with limiter) at rectifier and anode of V5. I have nothing at the other valves.
26th Apr 2022, 8:14 am | #58 |
Obviously something West of point 2 is pulling he HT down. With the 2-7 link removed what's the resistance from point 2 to chassis? Set turned off and unplugged of course.
26th Apr 2022, 10:32 am | #59 |
26th Apr 2022, 12:16 pm | #60 |
C84 is wired to point 2, so if it's electrically leaky that would explain the OP's problem.
