#521 |
Thanks for all the testing work you've done so far, Colin.
Would you mind if I used some of your screenshots in the instructions that will go on the Github page I'm starting for ToePost? I know you obviously don't mind Forum members and guests seeing them, but I thought it would be polite to ask for permission before sharing them with the wider world.
#522 |
It would be really nice to be able to help others - please use any of the screenshots I have provided.
I'm aware that my photography isn't always the best - if you need any better photos or photos of particular errors/events then please ask. I'm more than happy with the GPL v3.0 licence too. I'm a bit of a licence nerd and it's the one I would use in this situation. Colin. |
#523 | |
However, the (onsemi - Now obsolete on its product page) TIP29 Datasheet: https://www.onsemi.com/download/data-sheet/pdf/tip29b-d.pdf only specifies an hFE of 75 type / > 15 @ 1A. And >40 @ 0.2A. (Although from the graph, the hFE is a more-reasonable 200 typ. at currents < 0.1A - So nearly as much as a typical BCnnn transistor). It is odd that they never mention it being a darlington anywhere (maybe as it has a much lower gain than most of these), But as Vce(Sat) is 0.7V, then that is quite-high for a typical TO220 transistor at 1A that this is only rated upto - And maybe that's why it's only rated upto 1A, which could also make it more prone to failure in this application, with no over-current protection. These TIPnn transistors are also a bit different to other non TIP prefix transistors, in that their A/B/C suffix letter is the voltage rating - Rather than a pre-selected narrower group of the gain range. It will be interesting to see what the replacement ones measure. |
#524 |
Attached is what my tester makes of the replacement (not new by the looks of it) part.
Colin. |
#525 |
More screenshots, some from early in the list of errors (all in high memory) and one at the end of a complete cycle of tests.
I'm assuming that this is reporting that D6, D5, D3, D2, D1 and D0 are in error? I'm a bit confused why it reports errors in page 0000 as it passed the zero page check - is that a bug? Colin. |
#526 |
Fyi Julie, with a cassette player plugged in the motor runs all the time whilst running your test software.
Colin. |
#527 | ||
"4016 early high memory error.jpg" is similar to what I get testing an emulated 4016 with a version of ToePost built for 32K; read errors at location FF within a page of unpopulated memory. "4016 later high memory errors.jpg" is reporting refresh errors -- by which it means non-zero bytes found in a quick look at the page tested previously, and which would have contained all zeros before the delay subroutine -- but this condition isn't necessarily caused only by a refresh error. Stuck ones would cause the same symptom. I think the upper memory ICs probably are genuinely faulty (unless there's something going on that would prevent the upper memory, but not the lower memory, from being refreshed properly; I'm out until this evening, and haven't got all my notes with me, but anyone who's got the wiring diagrams in front of them can chime in). What happens if you do the CAS1 / CAS0 swapover now? Quote:
By "testing page 00 against page 7F", it means it is writing to page &00 and looking out for unexpected values in page &7F as well as in page &00. The last error message visible, "misread 7f00 as 6f with 01 in 00ff" means that after writing &01 to location &00ff, it searched all through page &00 except &00FF (i.e., the location it had written to), and found no non-zero values; but then while searching though page &7F, this time including &7FFF because if there is an address clash, we need to know about it, it found a non-zero value. And errors in the alternate page are (perhaps counter-intuitively) recorded against the "primary" page. That's something I hadn't even considered. I'm not actually touching the cassette motor control at all. (It might be a possible channel for feedback to the user, though .....)
#528 |
Got it - thanks. I'm away now for a few days so I'll make a start (one by one) on the memory when I return and report back.
Colin. |
#529 | |
The hFE does look to be about what's expected from datasheet, with quite large spreads between min. spec. and typical. Although the Vbe does look to be just a standard transistor, rather than a Darlington that it seemed these were plus on-semi datasheet gave Vbe of 1.3V. I wonder what a DMM's diode-test gives? However, even if these replacements aren't actually TIP29's, there are many non-Darlington standard transistors in that package that should work OK with a high-enough current-rating and DC-gain at Motor load current. In fact they could work better, if they have a lower Vce(Sat), which will be lower for a standard transistor compared to a Darlington. |
#530 | ||
It was the message
"page 00 failed 4141 errors" that confused me. Colin. Quote:
#531 | |
So I;d been expecting that, but maybe I'd misunderstood that (Plus it would really only make this logical for 32K PET's) According to: https://en.wikipedia.org/wiki/Commodore_PET It seems there were actually 4K versions of the PET (2001 at least (Although may not be encountered very-often, as probably too-low to run most software for it?) Or they didn't sell these in the UK ? (Like with Timex version of the ZX81, being 2K in the USA). |
#532 | |
I'll attempt to describe the circuit for motor #1. We start with UE16d {12, 13, 14} which is either cut off or saturated depending on the state of the output line from the PIA. R48 is the collector load of this transistor to the unregulated 9V supply. But, there's also VR6 between emitter and collector of UE16d. So the collector voltage is either the saturation voltage of UE16d (when it is saturated) or 7.5V (due to VR6) when it's cut off. The output stage, UE16c {10, 9, 8} and Q1 form a darlington something-or-other emitter follower. The motor output on the emitter of Q1 will be 2 or 3 diode drops lower than the collector of UE16d depending on just what Q1 is internally. So either essentially 0V (motor stopped) or around 6V stabilised (motor running). I seem to remember that in the Commodore cassette unit, this motor output simply connected to the +ve side of the motor, the -ve side being grounded. A stabilised supply is probably needed to keep the speed constant. |
#533 |
Well that's slightly-different from the results obtained by POKE & PEEK from BASIC (And the Tynemouth test), where although six DRAM's appeared to be faulty at the first upper 16K location, the datalines bits were slightly-different as it seemed D7,D6, D3,D2,D1,D0 were st fault - So difference of D7 & D5 being declared faulty between these.
#534 |
#535 | |||
One other thing has just struck me: If the output voltage of this circuit is just 'Stabilised' (rather than true feedback-regulation) then the exact Vbe voltage is important as it affects the output-voltage if just set by a zener etc. on the base of a transistor. As well as output-voltage not being as stable with load-changes. Hopefully the PET does use feedback-regulation (will have to refresh my memory of the circuit), otherwise the motor-speed could be dependent upon the transistor type used. |
#536 | |
#537 | |
Yes - and who is to say which test is 'best'. Certainly we know from before that the Tynemouth memory tests are good pointers but not conclusive. I think that either the PETTESTER (using a MARCH C test) or Julie's code are more exhaustive, and I can't get PETTESTER to test upper RAM right now for some reason.
My plan (such as it is) is to slowly, one-by-one remove/replace RAM chips starting with D0, D1, D2 and D3 and see every time whether the replacement of that chip allows either the PETTESTER or the Commodore diagnostic board that I built to see upper RAM, and if so perform their tests too. Something's stopping them getting at upper RAM for some reason and I don't know how we work that out with the tools we have. Anyway - that'll be in a week or so. Colin. P.S. I have put 6821s in the 4016 for now and the IEEE port works fine; I have had failures with this combination before so it all goes to prove that every PET has its quirks, even comparing to other 'like-for-like' PETs. Quote:
#538 | |
I think I might try omitting the alternate block tests in the final round of testing. I've thought of a way of doing that; it will add more code, but I should have (just) enough bytes of free space to fit it in. There might even be room to make it pause after a refresh test failure, but not if the refresh test passes and there's nothing new to see. I think I'm actually getting the hang of this weird way of coding without a stack or indirect addressing, though I'm glad I don't have to do it all the time! I suppose it gives you a bit of a feel for how programmers used to have it, in even earlier days than those of the PET .....
#539 | |
How critical the voltage is to give the right motor speed, and indeed how critical the motor speed is I don't know. The fact there's no adustment would seem to suggest 'not too critical' |
#540 |
Do the motors maybe have internal speed regulators, centrifugal, like most cheap domestic recorder / players?
