Old 29th Jul 2012, 3:22 pm   #1
Steve_P
Steve_P's Avatar
Default BRC 980 chassis – The set that came free with a BRC2000.
There is one problem that many sets have that is not caused by a courier's football match. The fact that somebody had 'been there' first. I was thinking this as I finished doing a Pye P116 set that had a simple fault that had taken ages to cure because of the person who had been there before. I sorted it in the end, by fair means and foul. But as it played away in the workshop, I wished for a simple job.
This was rare for me in itself, as I do enjoy fixing what most people would scrap. This comes from my PMR days, when various types of Taxi Driver used to bring in utter garbage and I was the only one in the workshop who would touch it sometimes and I used to get most of it going.
My eyes fell on a portable TV that had sat there for about a year, and the fact that it was supposed to work meant that it would be simple to sort, I thought. So, onto the bench it came and, with me being a man, I just plugged it in and stood back.
The sound, in the form of a hiss, came up but there was no sign of any vision on the screen. I twiddled Brightness and Contrast but still got nothing. So, heaving a sigh and reaching for a screwdriver or two, I disconnected the mains and removed the screws that held the back on. I then looked at the valves, reseated the PL81 and tried again.
Nothing.
One of the happy habits of a neon screwdriver is that when it is held against a LOPT or any line output valves. It will light if there is any activity in the line output stage. Of course there was none, and not any form of a spark from the top of the PL81.
Putting the set on its front so I could look at the circuit board immediately told me why. Some person had been soldering the line hold control and the power supply with a blowlamp, or so it would seem. Testing round the power supply revealed that one HT line was missing and looking back with the meter showed me where with a loud crack. Dilys was behind me at the time and started singing 'Go and get the fire brigade, get the fire brigade, let the building start to really burn.'
'What do you mean', I asked her.
'Nothing', she replied. 'I was singing a 60's classic as I was dusting'. There are often loud bangs here!
The area needed some work. So I pulled the mains from the set and carried on using the ohmeter. I soldered all the joints I could around the smoothing cap and the nearby fusible resistors, sometimes using wire when the print was not serviceable.
Then I moved to the line hold control and again, using a length of wire and my wits, it soon read OK. Right, time to try again. With the set reconnected to the mains. The sound came up, then there was line whistle and a raster. I then set the hold controls mid way and connected up the trusty 405 line generator.
The 1Khz tone came through and a couple of twiddles with the hold control brought in the line hold, but the frame hold was still dodgy and the frame lock could be made to come and go by moving the control. After a few prods with the iron, the frame hold and lock were stable.
The picture was low in width and off centre, so I tried a new PL81 and adjusted the tube controls to re-centre the picture. That improved it a lot, but while I had the set apart, I checked all the other parts that had been replaced. I let the set operate on the bench for a bit as I gave the back a clean.
I'd actually got this far without a circuit. Mainly because I was too lazy to get one. I know that I should have, but working with odd branded stuff often means that I am trained to work without. I would also note that 405 pictures are so good that one does wonder why we bothered with 625. One thing which I do want is a Contrast knob!
Pictures below were taken with a mobile phone – but if you're as much of an anorak as me, you should recognise the programmes here.
Cheers,
Steve P.
ID:	69160   Click image for larger version
ID:	69161   Click image for larger version
ID:	69162   Click image for larger version
ID:	69163   Click image for larger version
Steve_P is offline
Old 29th Jul 2012, 3:55 pm   #2
Refugee
Refugee's Avatar
Default Re: BRC 980 chassis – The set that came free with a BRC2000.
That set sounds like it had suffered a plumbing solder attack.
Refugee is online now
Old 29th Jul 2012, 8:45 pm   #3
Heatercathodeshort
Heatercathodeshort's Avatar
Nice one Steve! Great little receivers the Thorn 980. They worked well even in poor signal areas. I had a visit a while back from the guy that actually designed it! He did not have an example himself and had hankered after one for a while. He went away a very happy man..
They used to end up on the floor with broken printed circuit boards due to a rubbish plastic handle fracturing. A reel of 5 amp fuse wire, a fibreglass pencil, a temperature controlled soldering iron and some patience would usually restore normal service.
A few dry joints, leaky caps in the frame linearity loop and beefing up the line sync diodes was all that was required. Ideal jobs for my Saturday morning repair 'bar'!
Happy Days. John.
Heatercathodeshort is offline
Old 7th Aug 2012, 3:12 am   #4
Hybrid tellies
Hybrid tellies's Avatar
Nice one Steve. I use to own one of these when I was a kid, I think it was my first telly. It had a great picture and worked well on both channels just on its telescopic rod aerial. Sadly my brother accidently spilt some water over it and it was decided for me that it was two expensive for me to get it repaired, so it was scrapped.
Simon
BVWS member
Hybrid tellies is offline
