29th Mar 2023, 11:27 pm | #1 |
Diode Identification RS 51A
I like to find out about components that are hard to identify.
Got an axial metal case rectifier diode marked RS 51A possibly an old generic diode by Radiospares used as a low power mains rectifier diode, case like a DO 1 style. Anyone got any specs? Thanks from David |
30th Mar 2023, 12:13 am | #2 |
Re: Diode Identification RS 51A
250 volt r.m.s,500mA nr equivalent BY100. Les
30th Mar 2023, 3:14 pm | #3 |
Hello David
The only information I can find is in the old RS component applications data from 1971, and it lists a REC51A in the table on Silicon Rectifiers. Please see attached PDF file. I hope this information is of some use. If I remember correctly these devices did look like a BY100, with the cathode connected to the end with the flange and the case. Regards Stan.
Junk accumulates to fill the space available. |
30th Mar 2023, 3:17 pm | #4 |
These came in plastic cases and I think I still have one or two from the 60,s.
30th Mar 2023, 9:49 pm | #5 |
Thank you all that is very helpful, needed to check its specifications to know if it was suitable enough for what I am working on.
Thank you again from David |
