6th Apr 2007, 9:50 pm | #1 |
wavemeter type 1649
Hi everyone
I have the following piece of equipment, and i wonder if anyone could tell me anymore about it. Ita a wavemeter type W1649 made by Salford Electrical Instruments Ltd. Lookes like the main bit was made late 1944. A power supply has been added, the date on the caps in there is 1952. I gather the RAF used to use them, but what for ? Mike Burton |
6th Apr 2007, 10:43 pm | #2 |
Re: wavemeter type 1649
Hi Mike,
Wavemeters were used by the RAF and others to measure frequency- well wavelength in metres was actually used in those days. Measurements were made using a variety of principles such as tuned circuits/cavities, heterodyne and those using lecher lines and were often made as a piece of test gear to accompany a specific piece of equipment. They had a calibration graph that enabled the dial reading to be translated into wavelength or sometimes the dial was marked directly. There were ones for HF radio and there were ones for radar equipments. Wavemeters tended to operate over a limited band so an operator could be sure that his equipment was operating and also operating on the right frequency. Some had magic eye indicators to detect resonance and some used meters. Sometimes the output was a pair of phones so you could listen for zero beat frequency whilst tuning. The most common wavemeters around are probably the Class D wavemeter and the BC221. It looks like the dial on your unit is directly calibrated but I can't make out the details on the photo. Hope this helps. Alf |
7th Apr 2007, 9:57 am | #3 |
My only information on it is that it covers 140-250Mhz. Can you confirm that this is correct?
10th Apr 2007, 10:39 pm | #4 |
Frequency Range :
Wavemeter :155 - 255 Mhz Sig Gen :140 - 240 Mhz |
