Old 29th May 2014, 7:45 pm   #1
SurreyNick
Default Checking midget output transformer
Hi
This is the midget output transformer from my battery operated receiver (HT 120v / LT 2v accumulator). The writing on the side reads:
PRI:
BLUE & RED
MAINS PEN
& BATT. TRIODE
BLUE & GREEN
BATT. PEN
MAX 30 M/A. D.C.
Being a novice, that's pretty-much double Dutch to me.
Is there a simple way to check it's working properly without reconnecting it to the receiver?
Thanks
Nick
ID:	93564   Click image for larger version
ID:	93565   Click image for larger version
ID:	93566   Click image for larger version
SurreyNick is offline
Old 29th May 2014, 8:11 pm   #2
Station X
Station X's Avatar
Default Re: Checking midget output transformer
The best you'll be able to do is use a meter on ohms range to check the continuity of the windings. If they show open circuit, then the transformer is toast. If they show continuity, then the transformer is probably OK, but it may have short circuited turns.
Graham. Forum Moderator
Station X is offline
Old 29th May 2014, 8:19 pm   #3
SurreyNick
OK Graham, thanks, I think I know how to do that.
Regards
Nick
Old 30th May 2014, 12:07 am   #4
Herald1360
Herald1360's Avatar
Originally Posted by SurreyNick View Post
Hi
PRI:
BLUE & RED
MAINS PEN-------- Taps for typical mains powered radio output pentode for about 5K load
& BATT. TRIODE- Taps for typical battery radio output triode for about 5K load
BLUE & GREEN
BATT. PEN--------- Taps for typical battery radio output pentode for about 10K load
MAX 30 M/A. D.C.- Maximum continuous primary DC (anode current of O/P valve)
HTH
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 30th May 2014, 12:14 am   #5
SurreyNick
Thanks Chris, it does help
Regards
Nick
