Old 1st Mar 2007, 12:49 pm   #1
D o i v e
Default Hacker Hunter RP38A mains power supply
Hello all. Newcomer here, recently bought myself a nice Hacker Hunter RP38A (nothing to do with GJR, honest!). I've been wanting to power it up, but PP9 batteries are not readily available around here, only PP8s for electric fences. After checking the archives I spotted a recommended 18V transformer from CPC that others have used with this radio. On receiving it, I've found that all of the plugs to fit the power socket are too big to get through the wooden frame to the deeply recessed plug in the radio. So my question is, what have others done to make it fit? An obvious solution would be to make the hole in the radio body larger, but I don't want to go cutting my nice new toy. An alternative would be to remove the plastic outer on the plugs. I'm just interested to hear what others have done.
Ta, Doive.
D o i v e is offline
Old 1st Mar 2007, 1:45 pm   #2
howard
howard's Avatar
Default Re: Hacker Hunter RP38A mains power supply
Hello Doive,
I shouldn't modify the cabinet of your Hunter as that will drastically reduce it's value ! I have an 18v PSU, no doubt similar to yours, but it came with the correct plug already fitted, see part way down this page ...
http://hometown.aol.co.uk/oldradioparts/oddsnsods.htm
I'm sure someone here knows where a suitable plug can be obtained which you can then fit to your CPC PSU.
http://www.robertsradio.co.uk/ba.htm
Howard.
Last edited by Darren-UK; 15th Aug 2007 at 12:12 am. Reason: Defunct link and ref to cars removed.
howard is offline
Old 1st Mar 2007, 3:51 pm   #3
Colin
Colin's Avatar
Hi Doive,
I have a spare long-reach 2.1mm plug that you're welcome to.
When you wire it into your PSU remember that it's CENTRE NEGATIVE for the Hacker.
Rgds
Colin
Name:	Hacker Power Plug Centre Negative.jpg
Last edited by Darren-UK; 15th Aug 2007 at 12:05 am. Reason: Removed superfluous PM and postal address reference.
Colin is offline
Old 6th Mar 2007, 11:10 am   #4
D o i v e
Thanks to Colin, I received a suitable connector plug for the Hunter last friday. Finally got round to connecting it to my power supply last night and powered the radio up after many years in storage. No smoke is a good sign. Reception on FM is excellent, the sound quality for such a relatively small radio is excellent. I'm hugely impressed, the Hunter is easily miles better than my almost new JVC hi-fi thing (now virtually redundant). I'm really impressed, and very happy. Thanks to all those who offered advice and parts.
