1st Mar 2007, 9:29 pm | #1 |
Pye 39J/H, I.F instability/whistle.
This radio works fine on all wavebands but there is an annoying whistle as you tune through stations (all wavebands). As you get nearer to each station the whistle decreases in frequency, disappears on the station (just about) and then re-appears and increases in frequency the other side of the station.
It's very pronounced and annoying. It's so bad on medium wave that only the main BBC stations can really be listened to. What's the cause, please, and how do I cure it? I have the circuit diagram.
Now that's the kind of Long Wave I like ! (Severn Bore near Gloucester) |
1st Mar 2007, 9:36 pm | #2 |
Re: Pye 39J/H with annoying whistle.
hmm...that sounds like there's a "beat oscillator" in the radio, the ones used in some amateur receivers...may be the IF amplifier oscillating...
1st Mar 2007, 9:36 pm | #3 |
This is beating at I.F. somewhere. Look at De-coupling and Coupling Caps on the I.F. Stage.
Cheers, Steve P
1st Mar 2007, 9:43 pm | #4 |
Hi John, I believe this set uses those red Mullard 'E' series valves, so check that the metalising is earthed properly, particularly the EF39, as bad contact can cause IF instability which results in the symptoms described. Binding the valve with fuse wire and connecting to the relevent pin usually works.
Regards, Mick. |
1st Mar 2007, 9:55 pm | #5 |
Thanks Renato, Steve and Mick. Yes, indeed it does use those red metalized valves and the coating on three of them looks very bad indeed near their bases.
I will have a closer look tomorrow.
1st Mar 2007, 10:12 pm | #6 |
Yep, the EF39 coating is supposed to connect to Pin 1 but it doesn't ! It's missing round the bottom 1/8 inch of the valve (as it is on a couple of other valves). I can only connect my meter to it by scraping off more red, so I'll do that and try the fusewire trick.
Pin 1 on the valveholder connects direct to chassis, so could I take a wire from the fusewire wrapped round the (scraped) valve coating to any chassis point near the valve?
1st Mar 2007, 10:22 pm | #7 |
I'm a dum-dum ! It is the red coating that is the metalizing I've just realised ! Sorry to be so dim ! Working on it now.
1st Mar 2007, 10:23 pm | #8 |
Yes that was a common way of doing a repair on these valves. Wind the fusewire round the base of the valve and then run the end down the side of the base to pin 1. You will probably need to give the pin a quick touch with a file to get down to the copper.
As others have said, it's also worth checking decouplers. Good luck! Rich.
1st Mar 2007, 10:33 pm | #9 |
Metalizing on EF39 (I.F. amp) definitely earthed now but problem disappointingly remains.
I will tackle the other valves similarly tomorrow and report back but for now it's a to drown my sorrows.
1st Mar 2007, 10:35 pm | #10 |
Thanks for that, Richard. That is what I will do.
1st Mar 2007, 10:35 pm | #11 |
Don't forget obvious things like interference from TVs and computer monitors. It may be coming from next door
Paul |
1st Mar 2007, 10:41 pm | #12 |
Thanks, Paul. No, my computer wasn't on and in any case I've tried my other three radios in the same room and they're all working properly.
1st Mar 2007, 11:03 pm | #13 | |
Hopefully it will be nice and simple though! Rich.
2nd Mar 2007, 1:40 am | #14 | |
John |
2nd Mar 2007, 11:05 am | #15 |
All done ! Cured and working properly ! And I've got a red face because initially I jumped to a wrong conclusion and didn't spot there were TWO EF39s. Initially I "fusewired" the RF amp. to no avail but on "fusewiring" the IF amp. everything is hunky-dory.
Many thanks for all your help. Regards, John.
