30th Dec 2007, 8:22 pm | #1 |
Sobell type 516; cabinet finish.
Hello everyone
My neighbour upon hearing about my interest in vintage electronics delved into his garage and kindly gave me the above set. Luckily its also never been touched or 'modified' in any way. Hence the extremly dangerous rubber mains cable (whats left of it). The case is made of bakerlite and has a french polish effect paint on top, that is now peeling off the bakerlite case. How can i achieve a similar effect, as all the finish is going to have to be stripped back. Also what type of paint should i use ? Im guessing i use a base coat then apply a top coat, then brush over to make the polish effect. What do you all think ? Mike Burton |
31st Dec 2007, 12:42 am | #2 |
Re: Sobell type 516
Thats a nice set .
you could strip and just polish it as brown bakalite ,that may be the best option. it looks simlar to a large sobel set ,which i think is wooden |
31st Dec 2007, 12:44 am | #3 | |
Re: Sobell type 516
I'd do the same, i.e. just strip it and see what it looks like, and if it's ok, polish it. Trying to recreate the original finish would probably end up messy.
Nick. |
31st Dec 2007, 11:13 am | #4 | |
Re: Sobell type 516
I'm not sure what you mean by 'French polish' effect? From your photos, it looks like it's, originally, been painted a light brown If you can find a similar colour of aerosol paint, from Halfords etc, then I'd strip and respray it. Failing that I'd do what the other guys suggest and polish up the bakelite David |
31st Dec 2007, 1:00 pm | #5 |
Re: Sobell type 516
I rather like this [bakelite] set design although the colour scheme seems dull by modern standards and why cover brown bakelite with a brown finish? I think the answer may be the post war gloom. "Scumble" brown varnish, paint finishes were a household "improvement" feature. My father used to do them. Perhaps the "french polish" effect was aimed in the same direction. I'd stick with the bakelite if it polishes up nicely. Dave
31st Dec 2007, 5:44 pm | #6 | ||
Re: Sobell type 516
Might be a useful thing for wood cabinet restoration if done properly, but definitely not a good idea for bakelite!
Mike. |
