27th Sep 2018, 12:20 pm | #1 |
Cartridge ID
This cartridge was fitted to a Dynatron stereo with a Garrard SP25 Mk3. There are 100K resistors across the cartridge.
I presume its a ceramic cartridge can anyone confirm? |
27th Sep 2018, 12:36 pm | #2 |
Re: cartridge ID
Goldring CS90 - marketed as a hi-fi ceramic
https://www.musonic.co.uk/index.php?...oducts_id=7647 |
27th Sep 2018, 1:33 pm | #3 |
Re: cartridge ID
100k seems like rather a low load resistance for that, regardless of the Musonic suggestion of 1-2 milliohms
27th Sep 2018, 2:29 pm | #4 |
Re: Cartridge ID
A high impedance is only required for flat equalisation - it is also possible to feed into a lower impedance RIAA equalisation preamp, although then some attenuation may be needed to prevent overload.
27th Sep 2018, 3:00 pm | #5 |
Re: Cartridge ID
Good detective work on identifying cartridge.
Cheers John |
27th Sep 2018, 7:56 pm | #6 |
Re: Cartridge ID
Hi Michael. This is the description in Points on Pick Ups 1968.
David. |
27th Sep 2018, 8:00 pm | #7 |
Re: Cartridge ID
ISTR Dynatron recommending 100k in series with a ceramic cartridge when fed into one of their chassis with a RIAA preamp.
27th Sep 2018, 10:59 pm | #8 |
Re: Cartridge ID
I’ll check and report back, I’ve just got the stylus so we’ll soon see
