4th Jul 2018, 9:46 pm | #1 |
Unknown Pye Radio - Skip Salvage
Hi, my first proper post...
I've recently acquired a vintage Pye radio receiver from a skip. It's missing its output transformer, but all else seems to be present, and OK cosmetic condition albeit some wires disconnected. It's a four valve mains unit with an APV4 rectifier, AC2 Pentode, TH4B and VP4B RF valves. This is my second delve into valve amplifiers and my first into valve radio, so I'm hoping to learn a bit more this time having a lot more life experience to fall back on since last time (Leak TL10 restoration in the late 90's), and I'd like to start to learn what I'm actually doing regarding the valves, rather than just getting the job done. I've attached some photos of the unit, it appears to be similar to the MP, but I've not managed to locate an MP variant with an AC2 Pentode, so anyone's help would be appreciated here. I suppose first off I need to locate a schematic and test the valves I have to see if they are functional. I'll try to grab the data sheets, and check the heaters if nothing else this weekend. So any help or advice would be appreciated. Thanks Jon |
4th Jul 2018, 10:14 pm | #2 |
Re: Unknown Pye Radio - Skip Salvage
It can be useful to test the valves for heater continuity. Apart from that, the best place to test valves is in the set. Voltage readings will tell you all you need to know.
5th Jul 2018, 10:07 am | #3 |
It's in brilliant condition - or have you been cleaning it?
Peter |
5th Jul 2018, 11:15 am | #4 | |
Thanks Peter, I've done nothing to this unit yet, bar removing the chassis from the housing. As I say some wires have become disconnected around the transformer, and the OP transformer is missing, but yes looks in good condition.
Further investigation last night brought me to the Pye RS4, which looks an identical chassis, but not using an AC2 or APV4 (The RS4 uses a Pen4DD and a DW4/350), do I have incorrect valves in the unit? Quote:
Close up of full valve line-up attached. Rgds Jon |
5th Jul 2018, 1:57 pm | #5 |
It's amazing what some people throw out! That's a good find. The sets aren't particularly rare but to find one in that condition for nothing has got to be a bonus!
5th Jul 2018, 4:30 pm | #6 |
Hi Jon, I may be able to find you an op trans.
I take it that it is a 3R speaker, let us know what the op valve is when you get it sorted. Ed |
5th Jul 2018, 5:13 pm | #7 |
Hi Ed, Thanks, yes cone has a DC resistance of 3R.
5th Jul 2018, 5:18 pm | #8 |
Do not forget to change the output grid coupling cap and possibly run up through a lamp limiter.
5th Jul 2018, 5:27 pm | #9 |
Thanks, yes I have a varaic and a halogen limiter, but need to confirm a valid schematic, replace the loose wiring and confirm the connections of the possibly incorrect OP valve, then I'll need to look at replacing caps yes.
Do I need an OP transformer fitted to power it up? The AC2/PEN/DD fitted looks on first glance to have a different pinout, but the same socket to the PEN4DD on the RS4, so... assuming it is an RS4 I need to double check the pinout to see if someone has modified it to work with the AC2/PEN/DD or incorrectly fitted it while trying to get it to work. I've downloaded the schematic for the RS4 and all of the valve data for the RS4 valves, plus the ones fitted to my chassis. I'll double check and cross reference tomorrow. |
5th Jul 2018, 6:18 pm | #10 |
Seems unusual to find a Mazda valve fitted in a Pye. Think you need to check this out.
5th Jul 2018, 7:39 pm | #11 |
You will need an output transformer in the circuit if you don't want to run the risk of damaging the output valve.
Kevin |
5th Jul 2018, 7:53 pm | #12 | |
As mentioned the voice coil measured up at 3R DC Advice appreciated... Thanks |
5th Jul 2018, 7:57 pm | #13 |
That looks like a permanent magenet speaker to me (works in the same way as a modern speaker).
I wonder if the speaker was replaced at some point which might explain why the output transformer is missing. |
5th Jul 2018, 8:04 pm | #14 |
Thats definitely an option, from the marks on the enclosure, there has been a transformer (Choke/Transformer) frame screwed to the base next to the speaker at some point, but obviously cannot tell if this is an original placement or otherwise.
5th Jul 2018, 8:25 pm | #15 | ||
5th Jul 2018, 8:27 pm | #16 |
Where's the reservoir capacitor etc?
Lawrence. |
5th Jul 2018, 8:34 pm | #17 |
That's what I was thinking. The underside of the chassis looks rather Spartan than normal.
Should not be too difficult to fit a BVWS dual smoothing and reservoir electrolytic capacitor underneath Christopher Capener
Interests in the collection and restoration of Tefifon players and 405 line television |
5th Jul 2018, 8:44 pm | #18 |
There's a grounding lug North-West of the volume control that looks as though its had a snip.
Lawrence. |
5th Jul 2018, 8:54 pm | #19 |
Good call, missing is my best guess.
C29 should be an 8+8uF capacitor, this is nowhere to be seen, I assume it should be around the red and black coming to and from the non existent field coil. Any idea what value the choke (assuming I replace it with a choke, and not a field coil) should be? |
5th Jul 2018, 9:23 pm | #20 |
I think somewhere around 10H was a common value for HT choke for receivers, trouble is the DC resistance will probably be a lot lot lower (only 300-500 ohms maybe) than the DC resistance of a loudspeaker field coil, if going by the RS4 schematic that's 3,000 ohms, one suggestion would be to get a standard 10 henry choke that's good for at least 60mA, fit a 16uf for the reservoir and filter and fit a surge limiter in each anode of rectifier or between the cathode of the rectifier and the reservoir capacitor to drop the HT to what it should be, not sure what values off hand because it's a bit too hot for me to think straight at the moment
Lawrence. |
