14th Jul 2015, 11:13 am | #1 |
Coil Formers
I have a pair of Coil Formers. They were sold as Eddystone, but are un-marked.
There are six pins, which do not correspond with an Octal valve base. They are a larger diameter circle and the pins are thicker. To use these I am going to need something to plug them into. I don't know their age, so I don't know if the 'right thing' would be for screw fit to a baseboard or into a punched chassis hole. |
14th Jul 2015, 4:39 pm | #2 |
Re: Coil Formers
Except for missing pin1, it looks like it could plug into a B7 valve base.
14th Jul 2015, 9:04 pm | #3 |
Re: Coil Formers
Hi Neil, it may be possible to get insulated sockets for these depending on the pin diameter.
In use they were often plugged into simple turned brass sockets that were fitted into the ebonite baseboard. Do you have access to a lathe? Ed |
14th Jul 2015, 10:22 pm | #4 |
Re: Coil Formers
Similar coil formers (plain as yours evidently originally were, or threaded at 14 tpi), various made-up coils wound on the formers, and two different types of socket for them, are illustrated in the 1938 Eddystone Short Wave Components Catalogue: PDF extract attached. Possibly yours pre-date 1938 as they have straight split contact pins rather than the helically slotted pins of the 1938 versions.
